  • Replies 79
  • Views 35.1k
  • Links updated.
  • version 3.1   What's new:
  • "Notify me" should be the default behavior. (installed without switch).     With the ai switch the service is completely uninstalled (for those who don't want to have a service running in the backgrou
  • 4 weeks later...
  • 4 weeks later...
  • 3 months later...
Hello, nice to meet you. "Flash Player Plugin SFX & AddOn Maker" I use it to create addon flash player NPAPI.
What should I do to activate autoupdate? I addon created but the file "entries.ini" he says "Disable Auto-Update:" FL_NPAPI.exe -ai ".
I have to extract archive and edit "entries.ini"?
Pier
Guess something has been changed on adobe servers, links like these (used in the maker):
http://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player_ax.exehttp://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player.exehttp://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player_ppapi.exe
Are still pointing to flash 17.0.0.169, but links like those:
http://fpdownload.adobe.com/pub/flashplayer/latest/help/install_flash_player_ax.exehttp://fpdownload.adobe.com/pub/flashplayer/latest/help/install_flash_player.exehttp://fpdownload.adobe.com/pub/flashplayer/latest/help/install_flash_player_ppapi.exe
Seem to work fine and pointing to latest 17.0.0.188 ;)
Yup, it's about time for adobe to do so. Thanks for 3.2 ;)
Also wondering if this change will soon apply to Shockwave, because I've tried to replace 'macromedia' to 'adobe' in current static link
http://fpdownload.macromedia.com/get/shockwave/default/english/win95nt/latest/sw_lic_full_installer.exe
http://fpdownload.adobe.com/get/shockwave/default/english/win95nt/latest/sw_lic_full_installer.exe
And both work well :)
  • 4 weeks later...
  • 3 months later...
Hi mooms,
sometimes, like today, Adobe Flash comes in two different versions for IE & FF (or three, but I don't check PPAPI), but the dual installer get the lowest version number.
I changed line 196 in the script
copy /b %SFX% + ".\bin\Flash_ax_np.cfg" + ".\temp\Flash.7z" ".\output\SFX_Flash_AX_NPAPI_%vax%_%vnp%.exe"
but the name of the generated installer is a bit too long (SFX_Flash_AX_NPAPI_20.0.0.228_20.0.0.235).
Is there another possibility?
TNX & Regards, Thiersee
It's not the lowest version, it's the version of the first plugin (ActiveX here).
It's not perfect when there are multiple version numbers, but I had to make a choice to avoid a too long filename.
If you just want to check the versions number, you can create an addon (choice 2 in question 2), it will show full versions in the ini file:
version=Active X: 20.0.0.228  NPAPI: 20.0.0.235
Flash is usually updated every second Tuesday of the month exactly like Windows updates.
I will make an update of the maker to create a text file containing the version of each installer: this will avoid confusion if version numbers are not the same across editions, and shorten the file name.
