December 27, 201311 yr Is it possible to add a shotcut ofcontrol panel for desktop icons(such my computer, mydocuments, internet exploreretc. ) so that after the installationof window control panel icon isalso shown with other desktopicons.
December 27, 201311 yr Yes it should be simple, give me a few days to fix my PC and I can make an option (same as my ie icon on desktop tweak) in the folder options for CPL icon on desktop (or use the ie tweak as an example to make the cpl one)
January 5, 201411 yr I wrote an inf to create the shortcut on XP. Has also attach below for download.Feel free to try it. Pls change the extension from .txt to .inf;inf file name: CP_SC.inf[Version]Signature=$Windows NT$[DefaultInstall.NTx86]RegisterDLLs=Start.Register[Start.Register]11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %1%\%infname%.inf,Install"[Install.NTx86]CheckAdminRights=1ProfileItems=AllDesk.CPShortcut[Optional Components]CP[CP]OptionDesc =Control Panel ShortcutTip =Control Panel Shortcut on All User's DesktopModes =0,1,2,3ProfileItems=AllDesk.CPShortcut[AllDesk.CPShortcut];0x8,16 = "%UserProfile%\Desktop", 0x8,25 = "%AllUsersProfile%\Desktop"Name =%ShortcutN1%,0x8,25 ; All user's desktopCmdLine =11,,control.exeIconPath =11,,shell32.dllIconIndex =21[Strings]Infname=CP_SCShortcutN1=Control PanelCP_SC.txt
January 6, 201411 yr Perhaps you can run a batch command during XP setup to create Control Panel icon on desktopmd "%allusersprofile%\desktop\Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
February 1, 201411 yr Author geej sir i am not a master of xp.Please tell me how to integrate this .inf file to the xp cd.
