malcolmx Posted December 29, 2013 Posted December 29, 2013 Hello, I have encountered problem with a UX theme patcher,after choosing that option in Win Toolkit, during final phase of installation I receive a prompt as in attached screenshot,anyone has any ideas maybe ? Or is it caused maybe by some integrated update? many thanks for any help in advance Quote
Tolios Giorgos WhiteDeath Posted December 31, 2013 Posted December 31, 2013 go on reg file and remove the say -ms silent patcher find and delete is that is solution.! Quote
malcolmx Posted December 31, 2013 Author Posted December 31, 2013 I am not sure if I know what exactly to do , but - I have already worked this around by manually replacing files being patched and it works as a charm.Thanks anyway Quote
NewOne Posted January 2, 2014 Posted January 2, 2014 as i see its the same problem im having and posted here: http://www.wincert.net/forum/topic/11671-messagebox-error-while-installation-after-using-tweak/ maybe a mod could merge them together? Quote
Legolash2o Posted January 3, 2014 Posted January 3, 2014 I've fixed this issue in the latest build. Quote
