Here is a batch that will download Firefox in the language & version of your choice and create custom switchless installer.
Available options:
  • Choose Firefox language
  • Choose Firefox version or use latest (stable, beta, esr, dev, nightly) available
  • Make Firefox the default browser
  • Add custom profile with extensions & customizations (a sample profile is provided)
  • Keep or delete Desktop icon
  • Create nLite/RVMi AddOn
  • Make x86, x64, or AIO installer.
How-to use:
  • - Extract the content of the archive in a work folder.
  • - Run Firefox_SFX_Maker.cmd
  • - You can skip one or more questions, see the readme file.
The created SFX installers are made in the output folder.
Firefox_SFX_Maker_5.5.7z
SHA-1: 2bb1a9eec6a000683acb24428a7ab9b80ecb3472
  • Replies 85
  • Views 33.1k
  • Version 4.1 is out.   What's new:
  • I've finally found the time to work on this, so version 4 is out,. @NaJeEb303 @hamzaaan  your wish is fulfilled: What's new: You can now make AIO (x86 & x64) SFX. The setups are un
  • Updated again. Version 3.1:
  • 6 months later...
  • 6 months later...
  • 4 months later...
  • 3 months later...
Hello mooms,
Firefox 42 x64 came out yesterday as stable version.
Is it possible to you to make your switchless installer compatible for both X64 and/or X32 version ?
Thanks in advance !
Edited by rhahgleuhargh
  • 4 months later...
Updated the script to v3.
Changelog:
- You can choose which version you want to use (latest, specified, 32, 64)
- Added an option to make Firefox the default browser when the SFX is executed.
-  The creation of the RVMi/nLite AddOn is now optional.
- You can add your own extensions.
- The desktop icon is now deleted
Updated again.
Version 3.1:
Quote
- Corrected a mistake in the default browser config file: now it works with X64 as well (you can even install x86 Firefox on x64 Windows).
- Added  x86 & x64 in the filename to differentiate the SFX
- Updated the extensions, you can test it with setting ext=1
HelLo . .
My suggestion: An AIO version would be great , which will automatically detect the OS bit and install the correct version, so a single SFX can be used on any OS !
ThanX :rolleyes:
Edited by NaJeEb303
