clarkg888 Posted January 6, 2014 Posted January 6, 2014 I am running WinToolkit in Windows XP and trying beta4 and beta5 and get this error when I get to first screen of AIO Integrator: D:\Windows\Temp\WinToolkit\Imagex.exe is not a valid Win32 application. Lego posted this change in the beta: *1.4.1.29^Updated Imagex with Windows 8.1 version So, it looks like this new version of Imagex won't run in Windows XP. Lego mentioned in another post that he will remove Windows XP support with the 'school project' version, but I am hoping he'll keep this version going with XP for a while yet. Would it be possible to use the earlier version of Imagex when run under XP? What does the new Windows 8.1 version provide that the older version doesn't? Thanks,Clark. Quote
Legolash2o Posted January 6, 2014 Posted January 6, 2014 I will fix that, what version if windows are you using? 32 or 64 bit Quote
clarkg888 Posted January 6, 2014 Author Posted January 6, 2014 I'm running the regular Windows XP Professional 32 bit. Quote
