hello
i was using version .29 beta 7 and i wanted to use some tweaks (wintoolkit offers) but after starting the process and wintoolkit mounting my .wim it takes nearly 2 minutes at "getting --- list" i forgot what it was (the one bevor getting drives)
i tried again with importing registry tweaks --> same result
i dont know if that happens also when i would remove or integrate something but with wintoolkit .28 it took some secondes (maybe 10-20)
ah i forgot to say i used windows 7
if it really is a  problem of the new imagex, is there a way so self select the old one? or something like that?
thanks for fast replying ;)
I've put the old one back anyway, more hassle than it's worth! :P
So much for improvements on technology.  Maybe the newer one does more checks than the older imagex?  (Just throwing out conjecture.)
Probably, either way.... The newer version has gone back to the older one. I wonder if the older imagex you use, the faster it'll be :P
And we shall call this Legolash2o's axiom. lol
