Hi Lego,
did you change something in the sequence, how silent-installers are being installed?
In the past they have been installed in the sequence they have been put in WTK, now  apparently without any logical sequence!
And the WTK-installer-window does NOT scroll to the program just installing (but the install-counter goes on);
KB2603229, KB2592687 and KB2533552 will NOT install!
BTW, for me it was better with the "old" buttons to select/deselect all.
Edited by Thiersee
It installs in alphabetical order i believe. I'll fix it :)
Test 14.
Just tested, same as before...
Until Test10B it was in the same order as in WTK under silent-Installers.
Is it possible to get the same sequence back?
Edit:
I've put the installers in WTK in alphabetical order, but the windows does still NOT scroll, to see the actual program during install; only the counter continues counting.
Edit 2:
Test 15 is now installing in the same sequence as in WTK/Installer-tab
Edited by Thiersee
