March 10, 201411 yr Author You mean for install or on-demand upgrade?For install i dunno, i suppose setup.exe (and all sub-threads) get full resources, because no other processes are running while install progress.For on-demand, you can set higher process priority in taskmgr: start->run->taskmgr->*ENTER* -> processes -> setup -> *right-click*->process priority->High. Greez
March 11, 201411 yr and you have to integrate Platform before IE11 CABs Can you please clarify what you mean? Will the latest release automatically integrate platform before IE11 CABs?
March 11, 201411 yr Author @CarlJIn update download/repository directory (WHD,abbobi source), in Additional folder exist a folder/update called "Platform" and "Platform Updates".You have to integrate these at first, then finally IE11cabs.
March 12, 201411 yr @BrokenZer0, Thank you for the quick response! I am in the process of completing a project very close to what yours was. After deleting the ei.cfg, none of the images are green. Did you have to integrate updates/drivers/etc one image at a time and then rebuild all 64 bit images? Were you able to select all images from inside the WIM Manager, using a single source such as Win 7 Ultimate x64 ISO, and then have Win Toolkit integrate them all? UPDATE FOR NEW USERS LIKE ME: After deleting the ei.cfg so all image options are white, after selecting all images, it integrates updates into all builds and works. Edited March 13, 201411 yr by CarlJ
March 15, 201411 yr Author For my personal i delete all images except Ultimate and integrate all updates just in this.If u wish to integrate in all, click the the button at bottom "select" and "select all".
March 16, 201411 yr Author Update:I'm planing to release a full tutorial for get "FULL 2014"-Disks, but it need some time.At the moment i have to do something, girl-friend, other projects and school-stuff... At first much thanks at abbodi1406, Alphawaves and ofcs Legolash2o.
September 7, 201410 yr @BrokenZer0 Hey, are you still working on a tutorial or explanation how to get a fully up2date Windwos 7 x64 ISO?
September 8, 201410 yr Author At the moment you just need to use WHDownloader / WHD for download the repos and integrate all.Next time you will see a full turorial (includes the how to get FULL) on this thread: http://www.wincert.net/forum/topic/12571-project-win81-z3r07s-rog-edition/
September 10, 201410 yr I simply apply all languages that i need, then i run Simplix Pack And after that i add .net, as more i don't need right now, though thinking of adding drivers.
September 10, 201410 yr Author Project continues into that:http://www.wincert.net/forum/topic/12571-project-win81-z3r07s-rog-edition-beta-thread/ Edited September 13, 201410 yr by BrokenZer0
