Posted January 11, 201411 yr What do people think about the latest test version of v1.4.1.29? Do you think it's safe to release? *1.4.1.29^FIX: Fixed default browser detection*1.4.1.29^FIX: Fixed issue replacing strings*1.4.1.29^FIX: FAT32 now hidden on USB Boot Prep if partition > 32GB*1.4.1.29^FIX: AIO did not cancel rebuild WIM*1.4.1.29^FIX: Remove WinToolkit_Mount properly*1.4.1.29^FIX: Detection of unmounted images*1.4.1.29^FIX: Exlusive ISO links*1.4.1.29^FIX: IE11 exe did not integrate*1.4.1.29^FIX: IE11 did not add for non-english version.*1.4.1.29^FIX: IE11 now back at priority group*1.4.1.29^FIX: AIO Creator buttons remained visible.*1.4.1.29^FIX: AIO Disk Creator couldn't add other images*1.4.1.29^FIX: RunOnce no longer runs during Windows installation.*1.4.1.29^New RunOnce Installer*1.4.1.29^New theme patcher now supports Windows 8 and 8.1*1.4.1.29^Created 'Update' tab*1.4.1.29^Added RicaNeaga update repository*1.4.1.29^Updated Imagex with Windows 8.1 version
January 11, 201411 yr No problems found... yet. Just cosmetics and suggestions Safe to release i think. Update:One thing, i dont know if its matter, if its the tool or just "normal" (Test15):Some cabs are opened as folder (explorer popup max) in WinToolkit_Apps folder after install windows is done. (first desktop run)These cabs i have also integrate as cab and now found there: Fix_for_KB2652034; Fix_for_KB2697737; Windows_Virtual_PC_(KB958559) Edited January 11, 201411 yr by BrokenZer0
January 11, 201411 yr Only problem (for me) is that the installer-windows is still NOT scrolling down, neither automatically nor with scroll bar, so I can't see which programm is just installing.Just tested with 1.4.1.29_Test15. Thiersee
January 11, 201411 yr Please, fix the issue with IE integration order before releasing 1.4.1.29, so we can test it before the incoming patch Tuesday.
January 11, 201411 yr Author I made it so IE, Hyphenation, Spelling and IE LangPacks updates go into an 'Internet Explorer' group. But IE updates go into the normal group but I have added an option to right click on move to Internet Explorer group.
January 11, 201411 yr I made it so IE, Hyphenation, Spelling and IE LangPacks updates go into an 'Internet Explorer' group.That's perfect. But IE updates go into the normal group but I have added an option to right click on move to Internet Explorer group.That's not "idiot" proof, many unaware users will have issues with this setup.You should move them automatically at the bottom of the IE group.See this for more details and suggestions.An option to move any updates from their group is a good idea, it is more future proof.
January 11, 201411 yr Author If the file begins with "IE" (IE11-Windows6.1-KB2898785-x86) then it will go to the IE group. Test 16 released
January 11, 201411 yr Tested the integration order of IE11 French with test 16:All files have their original name. IE11 cab:Order is not good, hyphenation and spelling libraries are added before IE11 cab.See picture:IE11 exe:First, the IE exe is not added if I use add updates+subfolders, I had to use add updates and change the target from msu/cab to exe, I think this can be merged into one ?After succesfully added the exe, I can see the order is again not good, see the picture:Third test, just for completeness:If I rename IE files with "Z-number" in front (that the trick I use in 1.4.1.27), order in IE group is good, but KB2898785 is not added in IE group. (it is in the last entries of main group but this seems logical, it is not really a bug).See image:
January 11, 201411 yr Author IE will get moved up automatically when you click 'Start'. The EXE not adding during Add Updates + Subfolders is by design.
January 12, 201411 yr Indeed.I think you should move main cab/exe to the top of IE group before clicking start, seeing the actual integration order before pressing start seems more intuitive and should avoid confusion. I have launched the integration process in Win7 HP x86 French and IE Fr x86 + KB2898785, I will let Win Toolkit upload the log to you and reports here how integration & installation behave.
January 12, 201411 yr Great news. Sorry I couldn't test more lately, I was a little busy. Most likely on monday I'll also test what's latest, beta or stable Great work, Lego, mooms, Thiersee & co!
January 12, 201411 yr A question, have u ask Alphawaves what he think about to integrate the WHD Tool into WinToolKit (GUI integrate)?General what u think about the idea? So as new UpdateCatalog-GUI. Would that possible/workable to make this?Maybe then extending the updatelists for RiceNeaga Updates and a Office2010PostSP2-Source? And a other thing, the AIO check for superseded or?Whats about a SubTool to check a folder for superseds? That would realy greatfull upgrade.But at the moment, ofcs the Tool is still also fantastic work. - I realy love this one.
January 12, 201411 yr Author I feel cheeky asking someone to use their hard work but I will ask.UPDATE: I've asked. AIO doesn't check but Component Remover should show the superseded ones.Thanks
January 12, 201411 yr I just tested Test 18, for updates only and with silent-installer: no issue at all! For my purposes (I don't use ALL the features of WTK!) it is OK an can be released. Thiersee
January 12, 201411 yr Author YAY, if others say the same then I will release it to the general public.
January 12, 201411 yr Hi Just finished testing beta 18. :prop: Very good work. :thumbsup: Just a little thing: Is it possible to set IE11-Windows6.1-Kbxxxxxxx-x86(or64).cab on first place in Internet Explorer Group? And IE11-windows6.1-kbxxxxxxxx-x86(or64).msu to last place? It would the best way for unexperienced users. Only a idea.
January 12, 201411 yr Author Well when you click start it moves IE to the top of the group automatically. I believe the rest of the updates can be installed in any order after that
January 12, 201411 yr Just tested integration and silent installers on Win7 x86: all is OK.Will test with Win7 x64 and report here.edit:ok with x64.
January 12, 201411 yr I'm not able to find Run Once in a new version???Where is the problem?Thanks in advance!
January 12, 201411 yr Lego, small question: How should the folder with drivers in the root of the iso / ''usb stick / dvd be named so Win Toolkit's RunOnce detects the drivers and scans and installs from that folder? Thanks
January 12, 201411 yr Author X:\DriversX:\Sources\Drivers or you can specify in an install.ini within the sources folder.
