Posted January 15, 201411 yr Yay i found a bug (?!) /exceptopn what ever..(Hope here is correct place for post?) Title: Object reference not set to an instance of an object.ErrType: Error (1.4.29)Description: An unknown error has occurred and has been written to 'Logs\Errors.txt'Exception: Exception:***********************************Form: frmAllInOne (False)Status: Anti-Virus: FalseVersion: 1.4.29Unhandled Exception: Object reference not set to an instance of an object.StackTrace: at (Object ) at A..(Object , EventArgs ) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)InnerException: Source: WinToolkitTargetSite: SelectedListViewItemCollection (System.Object)Data: System.Collections.ListDictionaryInternalForm History: frmStartup, frmToolsManager, frmWIMManager, frmAllInOne, frmError, Open Forms: frmStartup, frmAllInOne, Produced by integrate much additional updates, then try to set "the" IE11 Update in the latest group under the IE self.Iv no idea whats going on there or if it fixed or almost reported, i just want to report as help. Update:I remember i had manny other exceptions in long past, i can try reproducing if wished. Edited January 16, 201411 yr by BrokenZer0
January 16, 201411 yr The order of integration should be: Internet Explorer 11IE SpellingIE HyphenationKB2898785
January 17, 201411 yr Your instructions to reproduce this aren't clear. So this happened when you tried to move an update to the IE group?
January 17, 201411 yr Author Yay, sorry iv forgot to call the specific Update, its this "KB2898785".The "the" cuz is the only Update which is in IE-Group. Strange, iv test it now again, i can also not any update move by click buttons, it result alltime in Exc.Also i cannot move any update to the IE-Group by using right-clickl, also the IE and IE-Group-Updates selfs back to IE-Group: Nohting happen. Buttons create exceptions or im (lol) the exception of exceptions? On 1/16/2014 at 11:39 PM, Snow said: Internet Explorer 11IE SpellingIE HyphenationKB2898785 Oh, evil..After just adding updates the order result: Quote KB2898785IE HyphenationIE SpellingInternet Explorer 11 What ive make wrong?Or its normal and i have to make self the right order? Update:WTF ?! I try again and now buttons works.. okay thats confusing me..pls help o.o Update2:Alltime if i start AIO-Integrate for first time resutls exception, then u see in Update(this post) suddenly works..Okay thats a bit strange... i can test more later today.. Edited January 17, 201411 yr by BrokenZer0
January 17, 201411 yr Still can't recreate the issue. Maybe you'll have to make a video or step-by-step instructions. At least you'll get more points
January 17, 201411 yr Author Hou Hou Hou :-)Okay i will try today after my monster-iso is done. (~800 Updates, 2,51GB ) Update:So im awake and have made quick the video now, u can see it here:(Remember u can set option for FullHD on youtube - Then u can see all in good quality) *video deleted, no more need* Remember; after a while, i dunno when, which requiirements or some, - the error disappair and i can move the updates without exception error... For more information like system-infos, just ask. Edited January 18, 201411 yr by BrokenZer0
January 18, 201411 yr Author Okay i will, but atm iv another big one here, after finish lets go. Update:Good Job! Both errors fixed (tested 1.4.30.8) Edited January 18, 201411 yr by BrokenZer0
