Posted January 17, 201411 yr Hi IE11 Files with a leading Z (number) are moved to Internet Explorer Section. That´s ok. Only the IE11 update marked as Z7 is set to end of normal updates evey time the preset is loaded and must moved manually to IE-Section. Is there a way to fix that? Regardswela
January 17, 201411 yr Remove the Z[number] in the name of the files.Win Toolkit can also use the exe setup of IE now.
January 20, 201411 yr Author @ Lego Using leading Z the problem exists (build 143012). Without Z no Problems. Edited January 20, 201411 yr by wela
January 21, 201411 yr It detects any filenames beginning with IExx-Windows.... So it's working as expected. Just remove the Z's.
