Be aware (from 5eraph http://www.ryanvm.net/forum/viewtopic.php?p=136570#136570) :
This is what I can find about JRE8 on XP:
  • Replies 214
  • Views 74k
  • Version 3.3 is out. Changelog:
  • papageorgiou
    papageorgiou
    Here was my solution.   I first noticed with 8u20 that the 64bit version when extracted had different file names so the rename commands failed. ren "%~dp0JRE_TEMP64\%JAVAFN64%_101_JAVA_INSTALLER.bin"
  • Version 2.3 of the script is on the first post.   What's new:   After some researches, I've found a way to extract the x86 MSI with ResourcesExtract: the x86 setup is compressed with UPX, once uncomp
That's great mooms!  I don't have access to an XP install to test myself, so hopefully 5eraph can confirm this, since he was the one that originally posted the problem.
  • 4 weeks later...
Hello mooms,
Wanted to ask if there is an option to include the -ai option directly into the SFX without showing the info message when SFX is ran.
Cheers
If you add the -ai switch the SFX is ran silently.
If you want it silent when double clicked or ran without any switches, you have to modify the script.
You have to understand the syntax of a 7zip SFX. There is many topics explaining it here, or see the help file.
I download the x86 & x64 package (jre-7u60-windows-i586 & jre-7u60-windows-x64). when i run the program i have error ''this installation package could not be opened. verify that the package exists...''
Do you have followed the instructions on the first post ?
How to use:
- Extract the archive in a work folder with no space in the path.
- Download the x86 and/or x64 Offline setup of Java 6/7/8 and put it in the same folder.
- Run the batch file.
Also check that the installers are not corrupted.
""Extract the archive in a work folder with no space in the path.""  Sorry but what is taht suppose to mean?
I do not understand.I use winrar and the program exstact the files properly I guess?
ren "%~dp0JRE_TEMP64\%JAVAFN64%_101_JAVA_INSTALLER.bin" jre64_inst.msi
ren "%~dp0JRE_TEMP64\%JAVAFN64%_102_JAVA_INSTALLER.bin" Data1.cab
needed to be changed to
ren "%~dp0JRE_TEMP64\%JAVAFN64%_105_JAVA_INSTALLER.bin" jre64_inst.msi
ren "%~dp0JRE_TEMP64\%JAVAFN64%_103_JAVA_INSTALLER.bin" Data1.cab
Then with 8u25, the files did not extract correctly, so I changed the script (see below) to launch the exe(s) and then grab the msi from the profile temp and then kill the exe(s).  It seems to work nicely so far.
The lines in bold are where the changes can be found.
@echo off
setlocal enableextensions
if not exist "%~dp0bin\7za.exe" goto :No7za
if not exist "%~dp0bin\JavaInst.sfx" goto :No7SFX
if not exist "%~dp0bin\ResourcesExtract.exe" goto :NoResExtr
SET SZ="%~dp0bin\7za.exe"
if exist "%~dp0jre-*-windows-i586.exe" GOTO :X86
if not exist "%~dp0jre-*-windows-i586.exe" GOTO :X64
:X86
if exist "%~dp0jre-*-windows-x64.exe" GOTO :DUAL
set JAVAFILE=
for %%j in (%~dp0jre-*-windows-i586.exe) do call :GETJAVAVER %%~nxj
if "%JAVAFILE%"=="" goto :NoJavaInst
for /f "delims=- tokens=2" %%j in ("%JAVAFILE%") do set JAVAVER=%%j
SET MAJ=%JAVAVER:~0,1%
SET MIN=%JAVAVER:~2,3%
if exist "%~dp0JRE_TEMP" rmdir /s /q "%~dp0JRE_TEMP"
mkdir "%~dp0JRE_TEMP"
::start /w "Unpacking JRE..." "%~dp0bin\ResourcesExtract.exe" /Source "%~dp0%JAVAFILE%" /DestFolder "%~dp0JRE_TEMP" /ExtractIcons 0 /ExtractCursors 0 /ExtractBitmaps 0 /ExtractHTML 0 /ExtractManifests 0 /ExtractAnimatedIcons 0 /ExtractAnimatedCursors 0 /ExtractAVI 0 /ExtractTypeLib 0 /ExtractBinary 1 /ScanSubFolders 0 /FileExistMode 1 /OpenDestFolder 0
::ren "%~dp0JRE_TEMP\%JAVAFN%_101_JAVA_INSTALLER.bin" jre_inst.msi
::ren "%~dp0JRE_TEMP\%JAVAFN%_102_JAVA_INSTALLER.bin" Data1.cab
::del /f /q "%~dp0JRE_TEMP\%JAVAFN%*"
ECHO.
ECHO Launching JRE 32bit to grab msi . . .
start "Launching JRE 32bit to grab msi . . ." "%~dp0%JAVAFILE%"
if exist "%~dp0JRE_ADMAIO" rmdir /s /q "%~dp0JRE_ADMAIO"
mkdir "%~dp0JRE_ADMAIO"
:DUAL32BITLOOP
IF NOT EXIST "%USERPROFILE%\AppData\LocalLow\Sun\Java\jre1.%MAJ%.0_%MIN%\jre1.%MAJ%.0_%MIN%.msi" GOTO :DUAL32BITLOOP
ping -n 10 127.0.0.1>nul
copy "%USERPROFILE%\AppData\LocalLow\Sun\Java\jre1.%MAJ%.0_%MIN%\jre1.%MAJ%.0_%MIN%.msi" "%~dp0JRE_TEMP\jre_inst.msi"
ping -n 2 127.0.0.1>nul
TASKKILL /F /IM %JAVAFILE%
start /w "Creating administrative installation point..." msiexec /a "%~dp0JRE_TEMP\jre_inst.msi" /qb! TARGETDIR="%~dp0JRE_ADM"
%SZ% a "%~dp0JavaInst.7z" "%~dp0JRE_ADM\*" -mx=9 -mmt=off -m0=BCJ2 -m1=LZMA:d27:fb=128:mc=256 -m2=LZMA:d24:fb=128:mc=256 -m3=LZMA:d24:fb=128:mc=256 -mb0:1 -mb0s1:2 -mb0s2:3 -r
call :CONFIG
copy /b /y "%~dp0bin\JavaInst.sfx"+"%~dp032.cfg"+"%~dp0JavaInst.7z" "%~dp0Java%JAVAVER%.exe"
rmdir /s /q "%~dp0JRE_ADM"
del /f /q "%~dp0JavaInst.7z"
mkdir "%~dp0svcpack"
copy /b /y "%~dp0Java%JAVAVER%.exe" "%~dp0svcpack\Java%JAVAVER%.exe"
call :ENTRIES_INI
%SZ% a "%~dp0Java_Runtime_%MAJ%_update_%MIN%_AddOn.zip" "%~dp0ENTRIES_Java.ini" "%~dp0svcpack"
del /f /q "%~dp032.cfg"
del /f /q "%~dp0ENTRIES_Java.ini"
rmdir /s /q "%~dp0svcpack"
exit /b
:X64
set JAVAFILE64=
for %%k in (%~dp0jre-*-windows-x64.exe) do call :GETJAVAVER64 %%~nxk
if "%JAVAFILE64%"=="" goto :NoJavaInst
for /f "delims=- tokens=2" %%k in ("%JAVAFILE64%") do set JAVAVER64=%%k
SET MAJ=%JAVAVER64:~0,1%
SET MIN=%JAVAVER64:~2,3%
echo JRE newest version found^: 1.%JAVAVER64%
echo Java file name only - %JAVAFN64%
if exist "%~dp0JRE_TEMP64" rmdir /s /q "%~dp0JRE_TEMP64"
mkdir "%~dp0JRE_TEMP64"
::start /w "Unpacking JRE..." "%~dp0bin\ResourcesExtract.exe" /Source "%~dp0%JAVAFILE64%" /DestFolder "%~dp0JRE_TEMP64" /ExtractIcons 0 /ExtractCursors 0 /ExtractBitmaps 0 /ExtractHTML 0 /ExtractManifests 0 /ExtractAnimatedIcons 0 /ExtractAnimatedCursors 0 /ExtractAVI 0 /ExtractTypeLib 0 /ExtractBinary 1 /ScanSubFolders 0 /FileExistMode 1 /OpenDestFolder 0
::ren "%~dp0JRE_TEMP64\%JAVAFN64%_105_JAVA_INSTALLER.bin" jre64_inst.msi
::ren "%~dp0JRE_TEMP64\%JAVAFN64%_103_JAVA_INSTALLER.bin" Data1.cab
::del /f /q "%~dp0JRE_TEMP64\%JAVAFN64%*"
ECHO.
ECHO Launching JRE 64bit to grab msi . . .
start "Launching JRE 64bit to grab msi . . ." "%~dp0%JAVAFILE64%"
:DUAL64BITLOOP
IF NOT EXIST "%USERPROFILE%\AppData\LocalLow\Sun\Java\jre1.%MAJ%.0_%MIN%_x64\jre1.%MAJ%.0_%MIN%.msi" GOTO :DUAL64BITLOOP
copy "%USERPROFILE%\AppData\LocalLow\Sun\Java\jre1.%MAJ%.0_%MIN%_x64\jre1.%MAJ%.0_%MIN%.msi" "%~dp0JRE_TEMP64\jre64_inst.msi"
TASKKILL /F /IM %JAVAFILE64%
if exist "%~dp0JRE_ADM64" rmdir /s /q "%~dp0JRE_ADM64"
mkdir "%~dp0JRE_ADM64"
start /w "Creating administrative installation point..." msiexec /a "%~dp0JRE_TEMP64\jre64_inst.msi" /qb! TARGETDIR="%~dp0JRE_ADM64"
%SZ% a "%~dp0JavaInst-x64.7z" "%~dp0JRE_ADM64\*" -mx=9 -mmt=off -m0=BCJ2 -m1=LZMA:d27:fb=128:mc=256 -m2=LZMA:d24:fb=128:mc=256 -m3=LZMA:d24:fb=128:mc=256 -mb0:1 -mb0s1:2 -mb0s2:3 -r
call :CONFIG_64
copy /b /y "%~dp0bin\JavaInst.sfx"+"%~dp064.cfg"+"%~dp0JavaInst-x64.7z" "%~dp0Java%JAVAVER64%-x64.exe"
del /f /q "%~dp0JavaInst-x64.7z"
del /f /q "%~dp064.cfg"
copy /b /y "%~dp0Java%JAVAVER64%-x64.exe" "%~dp0svcpack\Java%JAVAVER64%.exe"
call :ENTRIES_INI_64
%SZ% a "%~dp0Java_Runtime_%MAJ%_update_%MIN%_x64_AddOn.zip" "%~dp0ENTRIES_Java.ini" "%~dp0svcpack"
exit /b
:DUAL
set JAVAFILE=
echo JRE newest version found^: 1.%JAVAVER%
echo Java file name only - %JAVAFN%
ECHO.
:DUAL32BITLOOP
start /w "Creating administrative installation point..." msiexec /a "%~dp0JRE_TEMP\jre_inst.msi" /qb! TARGETDIR="%~dp0JRE_ADMAIO"
ECHO.
set JAVAFILE64=
ECHO.
:DUAL64BITLOOP
start /w "Creating administrative installation point..." msiexec /a "%~dp0JRE_TEMP64\jre64_inst.msi" /qb! TARGETDIR="%~dp0JRE_ADMAIO"
%SZ% a "%~dp0JavaInst-AIO.7z" "%~dp0JRE_ADMAIO\*" -mx=9 -mmt=off -m0=BCJ2 -m1=LZMA:d27:fb=128:mc=256 -m2=LZMA:d24:fb=128:mc=256 -m3=LZMA:d24:fb=128:mc=256 -mb0:1 -mb0s1:2 -mb0s2:3 -r
call :CONFIG_AIO
copy /b /y "%~dp0bin\JavaInst.sfx"+"%~dp0AIO.cfg"+"%~dp0JavaInst-AIO.7z" "%~dp0Java%JAVAVER64%-Dual.exe"
del /f /q "%~dp0JavaInst-AIO.7z"
del /f /q "%~dp0AIO.cfg"
copy /b /y "%~dp0Java%JAVAVER64%-Dual.exe" "%~dp0svcpack\Java%JAVAVER64%.exe"
call :ENTRIES_INI_AIO
%SZ% a "%~dp0Java_Runtime_%MAJ%_update_%MIN%_Dual_AddOn.zip" "%~dp0ENTRIES_Java.ini" "%~dp0svcpack"
exit /b
:CONFIG
ECHO ;!@Install@!UTF-8!> "%~dp032.cfg"
ECHO SetEnvironment="swUninst_x64=HKLM\\SOFTWARE\\Wow6432Node\\Microsoft\\Windows\\CurrentVersion\\Uninstall">> "%~dp032.cfg"
ECHO SetEnvironment="swUninst_x86=HKLM\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall">> "%~dp032.cfg"
ECHO SetEnvironment="DelOldVer=%%%%P:hidcon:cmd /c For /F \"tokens=2 delims={}\" %%a In ('Reg Query %%swUninst_%%%%P%% ^| FINDSTR \"{26A24AE4-039D-4CA4-87B4-2F832[0-9A-F]*}\"') Do MsiExec /x{%%a}">> "%~dp032.cfg"
ECHO Title="Java SE Runtime Environment %MAJ% Update %MIN% x86">> "%~dp032.cfg"
ECHO BeginPrompt="\n\nThis will install Java %MAJ% Update %MIN% x86 with Web plugins\nAny previous Java x86 version(s) will be uninstalled first\n\n\nAvailable command-line switch:\n\n-ai\tSilent installation with Web plugins\n-ai1\tSilent installation without Web plugins\n\nClick \"OK\" to begin installation.  Click \"Cancel\" to exit.">> "%~dp032.cfg"
ECHO ExtractTitle="Java SE Runtime Environment %MAJ% Update %MIN% x86">> "%~dp032.cfg"
ECHO ExtractDialogText="Please wait while the installation routine is extracted">> "%~dp032.cfg"
ECHO FinishMessage="Java SE %MAJ% Update %MIN% x86 has been installed.">> "%~dp032.cfg"
ECHO GUIMode="1">> "%~dp032.cfg"
ECHO GUIFlags="6153">> "%~dp032.cfg"
ECHO MiscFlags="4">> "%~dp032.cfg"
ECHO RunProgram="%%DelOldVer%% /qn">> "%~dp032.cfg"
ECHO RunProgram="jre_inst.msi /qb!">> "%~dp032.cfg"
ECHO RunProgram="x86:hidcon:cmd /c \"%programfiles%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp032.cfg"
ECHO RunProgram="x64:hidcon:cmd /c \"%programfiles(x86)%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp032.cfg"
ECHO AutoInstall="%%DelOldVer%% /qn">> "%~dp032.cfg"
ECHO AutoInstall="jre_inst.msi /qn">> "%~dp032.cfg"
ECHO AutoInstall="x86:hidcon:cmd /c \"%programfiles%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp032.cfg"
ECHO AutoInstall="x64:hidcon:cmd /c \"%programfiles(x86)%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp032.cfg"
ECHO AutoInstall1="%%DelOldVer%% /qn">> "%~dp032.cfg"
ECHO AutoInstall1="jre_inst.msi /qn WEB_JAVA=0">> "%~dp032.cfg"
ECHO AutoInstall1="x86:hidcon:cmd /c \"%programfiles%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp032.cfg"
ECHO AutoInstall1="x64:hidcon:cmd /c \"%programfiles(x86)%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp032.cfg"
ECHO ;!@InstallEnd@!>> "%~dp032.cfg"
ECHO. >> "%~dp032.cfg"
GOTO :EOF
:CONFIG_64
ECHO ;!@Install@!UTF-8!> "%~dp064.cfg"
ECHO SetEnvironment="swUninst=HKLM\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall">> "%~dp064.cfg"
ECHO SetEnvironment="DelOldVer64=hidcon:cmd /c For /F \"tokens=2 delims={}\" %%a In ('Reg Query %%swUninst%% ^| FINDSTR \"{26A24AE4-039D-4CA4-87B4-2F864[0-9A-F]*}\"') Do MsiExec /x{%%a}">> "%~dp064.cfg"
ECHO Title="Java SE Runtime Environment %MAJ% Update %MIN% x64">> "%~dp064.cfg"
ECHO BeginPrompt="\n\nThis will install Java %MAJ% Update %MIN% x64 with Web plugins\nAny previous Java x64 version(s) will be uninstalled first\n\n\nAvailable command-line switch:\n\n-ai\tSilent installation with Web plugins\n-ai1\tSilent installation without Web plugins\n\nClick \"OK\" to begin installation.  Click \"Cancel\" to exit.">> "%~dp064.cfg"
ECHO ExtractTitle="Java SE Runtime Environment %MAJ% Update %MIN% x64">> "%~dp064.cfg"
ECHO ExtractDialogText="Please wait while the installation routine is extracted">> "%~dp064.cfg"
ECHO FinishMessage="Java %MAJ% Update %MIN% x64 has been installed.">> "%~dp064.cfg"
ECHO GUIMode="1">> "%~dp064.cfg"
ECHO GUIFlags="6153">> "%~dp064.cfg"
ECHO MiscFlags="4">> "%~dp064.cfg"
ECHO RunProgram="x64:%%DelOldVer64%% /qn">> "%~dp064.cfg"
ECHO RunProgram="x64:jre64_inst.msi /qb!">> "%~dp064.cfg"
ECHO AutoInstall="x64:%%DelOldVer64%% /qn">> "%~dp064.cfg"
ECHO AutoInstall="x64:jre64_inst.msi /qn">> "%~dp064.cfg"
ECHO AutoInstall1="x64:%%DelOldVer64%% /qn">> "%~dp064.cfg"
ECHO AutoInstall1="x64:jre64_inst.msi /qn WEB_JAVA=0">> "%~dp064.cfg"
ECHO ;!@InstallEnd@!>> "%~dp064.cfg"
ECHO. >> "%~dp064.cfg"
GOTO :EOF
:CONFIG_AIO
ECHO ;!@Install@!UTF-8!> "%~dp0AIO.cfg"
ECHO SetEnvironment="swUninst_x64=HKLM\\SOFTWARE\\Wow6432Node\\Microsoft\\Windows\\CurrentVersion\\Uninstall">> "%~dp0AIO.cfg"
ECHO SetEnvironment="swUninst_x86=HKLM\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall">> "%~dp0AIO.cfg"
ECHO SetEnvironment="DelOldVer=%%%%P:hidcon:cmd /c For /F \"tokens=2 delims={}\" %%a In ('Reg Query %%swUninst_%%%%P%% ^| FINDSTR \"{26A24AE4-039D-4CA4-87B4-2F832[0-9A-F]*}\"') Do MsiExec /x{%%a}">> "%~dp0AIO.cfg"
ECHO SetEnvironment="DelOldVer64=hidcon:cmd /c For /F \"tokens=2 delims={}\" %%a In ('Reg Query %%swUninst_x86%% ^| FINDSTR \"{26A24AE4-039D-4CA4-87B4-2F864[0-9A-F]*}\"') Do MsiExec /x{%%a}">> "%~dp0AIO.cfg"
ECHO Title="Java SE Runtime Environment %MAJ% Update %MIN% DUAL">> "%~dp0AIO.cfg"
ECHO BeginPrompt="\n\nThis will install Java %MAJ% Update %MIN% DUAL with Web plugins\nAny previous Java version(s) will be uninstalled first\n\n\nAvailable command-line switch:\n\n-ai\tSilent installation with Web plugins\n-ai1\tSilent installation without Web plugins\n\nClick \"OK\" to begin installation.  Click \"Cancel\" to exit.">> "%~dp0AIO.cfg"
ECHO ExtractTitle="Java SE Runtime Environment %MAJ% Update %MIN% DUAL">> "%~dp0AIO.cfg"
ECHO ExtractDialogText="Please wait while the installation routine is extracted">> "%~dp0AIO.cfg"
ECHO FinishMessage="Java %MAJ% Update %MIN% DUAL has been installed.">> "%~dp0AIO.cfg"
ECHO GUIMode="1">> "%~dp0AIO.cfg"
ECHO GUIFlags="6153">> "%~dp0AIO.cfg"
ECHO MiscFlags="4">> "%~dp0AIO.cfg"
ECHO RunProgram="%%DelOldVer%% /qn">> "%~dp0AIO.cfg"
ECHO RunProgram="x64:%%DelOldVer64%% /qn">> "%~dp0AIO.cfg"
ECHO RunProgram="jre_inst.msi /qb!">> "%~dp0AIO.cfg"
ECHO RunProgram="x64:jre64_inst.msi /qb!">> "%~dp0AIO.cfg"
ECHO RunProgram="x86:hidcon:cmd /c \"%programfiles%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp0AIO.cfg"
ECHO RunProgram="x64:hidcon:cmd /c \"%ProgramFiles(x86)%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp0AIO.cfg"
ECHO AutoInstall="%%DelOldVer%% /qn">> "%~dp0AIO.cfg"
ECHO AutoInstall="x64:%%DelOldVer64%% /qn">> "%~dp0AIO.cfg"
ECHO AutoInstall="jre_inst.msi /qn">> "%~dp0AIO.cfg"
ECHO AutoInstall="x64:jre64_inst.msi /qn">> "%~dp0AIO.cfg"
ECHO AutoInstall="x86:hidcon:cmd /c \"%programfiles%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp0AIO.cfg"
ECHO AutoInstall="x64:hidcon:cmd /c \"%ProgramFiles(x86)%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp0AIO.cfg"
ECHO AutoInstall1="%%DelOldVer%% /qn">> "%~dp0AIO.cfg"
ECHO AutoInstall1="x64:%%DelOldVer64%% /qn">> "%~dp0AIO.cfg"
ECHO AutoInstall1="jre_inst.msi /qn WEB_JAVA=0">> "%~dp0AIO.cfg"
ECHO AutoInstall1="x64:jre64_inst.msi /qn WEB_JAVA=0">> "%~dp0AIO.cfg"
ECHO AutoInstall1="x86:hidcon:cmd /c \"%programfiles%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp0AIO.cfg"
ECHO AutoInstall1="x64:hidcon:cmd /c \"%ProgramFiles(x86)%\\Java\\jre%MAJ%\\bin\\jqs.exe\" -unregister">> "%~dp0AIO.cfg"
ECHO ;!@InstallEnd@!>> "%~dp0AIO.cfg"
ECHO. >> "%~dp0AIO.cfg"
GOTO :EOF
:ENTRIES_INI
ECHO [general]> "%~dp0ENTRIES_Java.ini"
ECHO builddate=%date%>> "%~dp0ENTRIES_Java.ini"
ECHO description=Java SE Runtime Environment %MAJ% update %MIN% x86>> "%~dp0ENTRIES_Java.ini"
ECHO language=Multi>> "%~dp0ENTRIES_Java.ini"
ECHO version=1.%JAVAVER%>> "%~dp0ENTRIES_Java.ini"
ECHO website=http://www.java.com/>>"%~dp0ENTRIES_Java.ini"
ECHO. >> "%~dp0ENTRIES_Java.ini"
ECHO [EditFile]>> "%~dp0ENTRIES_Java.ini"
ECHO I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram>> "%~dp0ENTRIES_Java.ini"
ECHO [AddProgram]>> "%~dp0ENTRIES_Java.ini"
ECHO Java%JAVAVER%.exe -ai>> "%~dp0ENTRIES_Java.ini"
ECHO ; "Java%JAVAVER%.exe -ai1" for install without Web plugins>> "%~dp0ENTRIES_Java.ini"
GOTO :EOF
:ENTRIES_INI_64
ECHO description=Java SE Runtime Environment %MAJ% update %MIN% x64>> "%~dp0ENTRIES_Java.ini"
ECHO version=1.%JAVAVER64%>> "%~dp0ENTRIES_Java.ini"
ECHO Java%JAVAVER64%.exe -ai>> "%~dp0ENTRIES_Java.ini"
ECHO ; "Java%JAVAVER64%.exe -ai1" for install without Web plugins>> "%~dp0ENTRIES_Java.ini"
GOTO :EOF
:ENTRIES_INI_AIO
ECHO description=Java SE Runtime Environment %MAJ% update %MIN% Dual>> "%~dp0ENTRIES_Java.ini"
ECHO version=1.%JAVAVER%_x86 + 1.%JAVAVER64%_x64>> "%~dp0ENTRIES_Java.ini"
GOTO :EOF
:GETJAVAVER
if /i "%1" GTR "%JAVAFILE%" (set JAVAFILE=%1&&set JAVAFN=%~n1)
goto :eof
:GETJAVAVER64
if /i "%1" GTR "%JAVAFILE64%" (set JAVAFILE64=%1&&set JAVAFN64=%~n1)
goto :eof
:NoJavaInst
echo ================================================================================
echo. JRE x86 and/or x64 redistributable not found.
echo. Place it/them in the same directory than this script.
echo. Correct JRE install name for x86 is "jre-XuXX-windows-i586.exe".
echo. Correct JRE install name for x64 is "jre-XuXX-windows-x64.exe".
pause
goto :eof
:NoResExtr
echo. NirSoft ResourcesExtract not found. Download and unpack it in "bin" directory.
echo. Get it here - http://nirsoft.net/utils/resources_extract.html
pause
goto :eof
:No7za
echo. 7za.exe not found. Download and unpack it in "bin" directory.
echo. Get it here - http://sourceforge.net/projects/sevenzip/files/7-Zip/
pause
goto :eof
:No7SFX
echo. JavaInst.sfx not found. Place it in "bin" directory.
pause
goto :eof
Edited by papageorgiou
@echo off
:X86
set JAVAFILE=
ECHO.
:DUAL32BITLOOP
call :CONFIG
call :ENTRIES_INI
exit /b
:X64
set JAVAFILE64=
ECHO.
:DUAL64BITLOOP
call :CONFIG_64
exit /b
:DUAL
set JAVAFILE=
ECHO.
:DUAL32BITLOOP
ECHO.
set JAVAFILE64=
ECHO.
:DUAL64BITLOOP
call :CONFIG_AIO
exit /b
:CONFIG
GOTO :EOF
:CONFIG_64
GOTO :EOF
:CONFIG_AIO
GOTO :EOF
:ENTRIES_INI
GOTO :EOF
:ENTRIES_INI_64
GOTO :EOF
:ENTRIES_INI_AIO
GOTO :EOF
:GETJAVAVER
goto :eof
:GETJAVAVER64
goto :eof
:NoJavaInst
pause
goto :eof
:NoResExtr
pause
goto :eof
:No7za
pause
goto :eof
:No7SFX
pause
goto :eof
make this in cmd please..!! :crying_anim02:
@hamzaaan:
I don't understand your comment?  How is a cmd different than a bat file?  Can't i just copy and paste this text into a file and save it as a batch and run it like the cmd in the OP?
@hamzaaan:
Yes you can!! Dont worry! I made it a long time ago.The only problem is that Im not able to create dula(86-64) silent instalation of Java 8.25
@hamzaaan:
Will this work on XP?
Version 2.0 of the maker, what's new:
- The script will offer the choice of the version (x86, x64, or both).
- The script will automatically download the newest version(s) of JRE (only if the setup(s) are not already in the folder, so no unnecessary download).
- The script can still be used offline if you have put the setup(s) in the same folder.
- Fix: previous Java version(s) correctly uninstalled.
- The default install is without Web plugins
Hi mooms,
1) In the english batch-file there is a small section still in french:
:NoJavaInst
echo. L'installateur Java x86 et/ou x64 est introuvable
echo. Plachez-le(s) dans le même dossier que ce script
echo. Le nom correct pour  les versions x86 est "jre-XuXX-windows-i586.exe".
echo. Le nom correct pour les versions x64 est "jre-XuXX-windows-x64.exe".
pause
goto :eof
2) If I start the maker on a system, where the actual version is already installed, I get a small error-warning that a newer version is already installed on the system; this warning disappears on his own.
Regards, Thiersee
BTW: Happy New Year! :beerchug:
