January 17, 201411 yr Please advise on the exact lines I need to enter -- and where to enter – in the Autounattend.xml fileto make sure I can choose which partition to format & install to.Want to install to a partition other than my first partition and make sure that other partitions are not formatted.Are these the only lines needed and where are they placed?<DiskConfiguration> <WillShowUI>Always</WillShowUI> </DiskConfiguration>Are there any disk wipe options I can search for in Autounattend.xml ?How do I make sure the disk wipe options are not set?When I use VMware Player to install, it seems to not give a choice; but then it only has one “Virtual HDD” it is installing to and seems to be doing its own install thing (also asks for license key).Thanks
