See attached. I use the .cab version of IE11, but by default it isn't at the top of the ''postrequisites'' area. This isn't ok, especially if WinToolkit preserves that order when integrating). I noticed it and I used the arrows to move the IE11 .cab above its update.
LE: latest beta 9 of 1.4.30 :)
post-25565-0-14292300-1390142727_thumb.p
Edited by RicaNeaga
Since I have noticed this confusion now several times, maybe, if it can't put it in the "right/final" order to begin with, if there was some way, through some "Check Order" button or something, (That's a lousy name so don't use it. :) ), to see what the final order will be before you press "Start"  that might alleviate folk's concerns and prevent some of the "false" posts here saying it's messing up.  Just a thought.
