Thiersee Posted January 19, 2014 Posted January 19, 2014 Hi Lego, there are two bugs related to the preset-manager of 1.4.30.9: 1) checking the top-level of a preset does NOT check levels under it on 1.4.30.2 is correct 2) This presets can't be deleted with "Delete"-function, only manually in windows-explorerAfter Integration the preset-file still have the original name, but after terminating WTK they are changed automatically with those strange names. Again, in 1.4.30.2 it works correctly. Thiersee Quote
