Posted January 19, 201411 yr Aahrgs, dunno if it wanted, the WIm-Manager do rebuild after i unmount a folder.If i unmount a folder, so i dont need them more, i would delete after finished.Maybe a option for deactive this is need? ThanksGreez
January 19, 201411 yr If you mean the auto rebuild after AIO Integration. It can be disabled in the options tab.
January 19, 201411 yr Author No, i mean the rebuilding after i unmount a mounted folder in wim-manager: Steps:1. Start AIO-Integrator, choose in WIM-Manager integrate some updates, - Kill the task (WTK & wimserv)2. Start AIO-Integrator- the WIM-Manager will display and i see the mounted "unknow" - click unmount. (after i want to remove, cuz crashed progess)3. WIM-Manager do rebuild the image after unmounting - thats no realy need.
January 24, 201411 yr I'm pretty sure when you unmount it there is an option to not rebuild the image.
January 24, 201411 yr Author Oh yes, im very sorry, ur right!Didnt see this before.. :shy: Thread done
