Posted (edited)
For some strange reason, it only shows Last preset in preset manager.
Also it wont allow you to import any, complaining that file already exists.
All preset are created with 1.4.29 so are basically equal from that perspective.
Edited by Etz
Posted (edited)
Just noted that ISO-Maker wont allow any of the checkboxes (under options) to be unchecked or checked...
They dont seem to interact at all from GUI perspective.
Edited by Etz
Solved both issues. I've changed the way it stores version and date within the last session files. You will only see the version info and date from presets made with test 16 or higher.
