Options to remember the last iso/updates selection folder and to list the the path for them
ie if my iso's sit & my updates sit here
I:\ISOs\Os
I:\Updates\WUD
then thats the default place it goes to.
But say if i downloaded an new iso to test something and its in
F:\Firefox
then it would open I:\ISOs\Os but i can navigate to F:\Firefox to use the new iso
and then next time when selecting iso its ask me "Would you like to use your previous iso?"
Hello, I would like to know how I can manually rename the "WinToolkit_apps" folder by another name, what is the file that controls that folder and do not want to put programs on hand in that folder, I would like to save programs a folder within the custom route and DVD.
Thanks for the information they can give me.
I'm planning on re-designing the layout of the 'Options' screen within Toolkit. Is there any options you want me to add?
