AIO-Integrator: No Skip 8.0 Updates
Hey!
Im not sure,
but i think these updates are outdated, cuz theyre 8.0 may?
Windows6.2-KBXXXXXX-x64
Windows8-RT-KBXXXXXXX-x64
But WTK not skip by add, WTK try to integrate them and fails.
Up2Date Updates seems as:
Windows8.1-KBXXXXXXX-x64
Windows6.3-KBXXXXXXX-x64
Greez. :)
Update: EVIL:
evilbhzido4slu.jpg[/url
And an error message:
Exception:An error occurred whilst integrating an update!Exception:Microsoft Windows [Version 6.1.7601]Copyright (c) 2009 Microsoft Corporation.  All rights reserved.C:\Users\Zer0\Desktop\WinToolkit_1.4.31.4>Set SEE_MASK_NOZONECHECKS=1C:\Users\Zer0\Desktop\WinToolkit_1.4.31.4>"C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe"  /Image:"C:\WinToolkit_Mount" /Add-Package /PackagePath:"C:\Users\Zer0\Desktop\UP\Windows8.1-KB2911106-x64.msu" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.16384Image Version: 6.3.9600.16384Processing 1 of 1 - Adding package C:\Users\Zer0\Desktop\UP\Windows8.1-KB2911106-x64.msuC:\Users\Zer0\Desktop\UP\Windows8.1-KB2911106-x64.msu: The specified image is no longer serviceable and may be corrupted.Discard the modified image and start again. Error: 0x80070070Error: 112The specified image is no longer serviceable and may be corrupted.Discard the modified image and start again.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logC:\Users\Zer0\Desktop\WinToolkit_1.4.31.4>exit----------------------------------Something bad has happened to your image and can no longer be worked on! There was no point in continuing.NOTE: This usually happens when you try and integrate a language pack of some sort without integrating the Windows language pack first.-For example, if you want to integrate a French language pack for Internet Explorer. Then you need to make sure to add the French Windows language pack first!Exception:Microsoft Windows [Version 6.1.7601]Copyright (c) 2009 Microsoft Corporation.  All rights reserved.C:\Users\Zer0\Desktop\WinToolkit_1.4.31.4>Set SEE_MASK_NOZONECHECKS=1C:\Users\Zer0\Desktop\WinToolkit_1.4.31.4>"C:\Program Files (x86)\Windows Kits\8.1\Assessment and Deployment Kit\Deployment Tools\amd64\DISM\dism.exe"  /Image:"C:\WinToolkit_Mount" /Add-Package /PackagePath:"C:\Users\Zer0\Desktop\UP\Windows8.1-KB2913152-x64.msu" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.16384Image Version: 6.3.9600.16384Processing 1 of 1 - C:\Users\Zer0\Desktop\UP\Windows8.1-KB2913152-x64.msu: An error occurred applying the Unattend.xml file from the .msu package.For more information, review the log file. Error: 0x800f0830Error: 0x800f0830DISM failed. No operation was performed.For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logC:\Users\Zer0\Desktop\WinToolkit_1.4.31.4>exit----------------------------------
Meow.
Update:
Result by wrong order to integrate.
Retry with original folder names works.
Nice one, WTK now sort the folders for integrating? :)
Edited by BrokenZer0
