Posted January 24, 201411 yr Hi ! Thanks Lego for you great program and your support! It's very apreciated!I've made my custom windows 8.1 pro image and i installed the windows. When it comes to install silent installers it also installs me all the drivers from my second partition (the windows setup is run from there). In wintoolkit i didn't add any drivers. This is kind annoying. Is there any option to disable this? The image is made with WinToolkit_1.4.30.15 Edited January 24, 201411 yr by blagasamuel
January 24, 201411 yr I'm guessing your drivers folder is something like 'D:\Drivers\*' ? Good news is that it will only install the drivers it needs and detects for your system. Bad news is that you may have to rename your folder.
January 24, 201411 yr Author Yeah. It's exactly like that.So even if i move the "drivers" folder inside another one, it's gonna detect it?And even if install the win from usb stick it's gonna detect my "drivers" folder?
January 24, 201411 yr If you move it or rename it, then the RunOnce won't detect it. It just scans the roots of all the partitions for a 'Drivers' folder.
January 24, 201411 yr Author And another thing,i created an Autounattend file that incluedes only the serial and when i install window it still asks me for the serial. I copied the win 8.1 pro serial from the "Serial Keys" tab. I placed the file at the root (meaning where the setup.exe is located). And it would be nice if i can auto set the power plan to high performance
