Ouh.. hard project.
I think PE is a trimmed core version.
To customize it to add the complete GUI will be hard way.
You have to replace much of image, better way is to add PE Tools into a mobile OS version.
My personal recommendation: Get "UltimateBootDisk" and forgot the PE sh*t. ;)
You might want to check out this thread over at MSFN. Win7PE SE  Looks like it might be what you are looking for.
There are also versions that are based on Win8
and Win8.1.
I believe that all three of them now include, or can access, JFX's WinNTSetup3 (v3.2.1) x86/x64 which, AFAIK, can be used to install Windows 2k/XP/2003/2008/2012/Vista/7/8.x x86/x64
