AxCrypt - Password Protect Files With Strong Encryption
AxCrypt is the leading open source file encryption software for Windows. It integrates seamlessly with Windows to compress, encrypt, decrypt, store, send and work with individual files.
AxCrypt is translated into English, Czech, Danish, Dutch, Finnish, French, German, Hungarian, Italian, Norwegian, Russian, Polish, Spanish and Swedish so chances are it speaks your preferred language.
Website - Features
Info: Repack with 7zSFX, Slim and Unattended.
DOWNLOAD
MD5: 47D275ADD8F4014B560029F1A0E6D788
Version: 1.7.3156.0
@Vandit, No, I didn't try to install it since I don't use AxCrypt or any other encryption app.  But I wouldn't think that JCM would purposefully put out an app with spam.  EXACTLY what SPAM did you find?  If it is there, I would think it was an accident which he will remove.  But then, if whatever it is was included by the creator of AxCrypt which JCM just neglected to remove, then he still didn't do anything "wrong".  If not, then that is a different matter, of course. :)
