spidernz Posted January 31, 2014 Posted January 31, 2014 So I made a vanilla iso of Windows 8.0 pro wmc with .net enabled. with advanced component remover i can remove things from it fine,However if i integrate the updates then try remove things it wont work :/ seems to remove themes and a few things from the first section but anything after it process through fine without errors but comes back showing all the packages still there.2014-01-30_23-35-33_test2.ini Quote
spidernz Posted February 2, 2014 Author Posted February 2, 2014 (edited) Ok just tried this with windows 8.1 as well same issue, and updated iso i cannot remove most of the components. I use this script to build a 8.1 with wmc & .net enabled and updated iso then i use wtk on it the AIO side since advanced component remover doesn't show much.Also it seems like its working on it, take about 3hrs which isn't normal. Usually any reduction is done in 15-20mins.Rem "WMC & .NET 3.5 (include .NET 2.0 and 3.0) Enabler & Excess Package Remover Updated 31/01/2014"Rem "Make Sure Running As Administrator"Pause@echo OffEcho "Clearing Existing Directories and Recreating""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Cleanup-MountpointsDEL /F /Q "D:\Win81\*.*"RD /S /Q "D:\Win81"DEL /F /Q "I:\Apps\Wmc Builder\Logs\*.*"RD /S /Q "I:\Apps\Wmc Builder\Logs"DEL /F /Q "I:\Apps\Wmc Builder\8.1 Features\*.*"RD /S /Q "I:\Apps\Wmc Builder\8.1 Features"MKDIR "D:\Win81\"MKDIR "D:\Win81\Iso"MKDIR "D:\Win81\Mount"MKDIR "D:\Win81\Scratch"MKDIR "D:\Win81\BootMount"MKDIR "D:\Win81\Wim"MKDIR "D:\Win81\BootWim"MKDIR "I:\Apps\Wmc Builder\Logs"MKDIR "I:\Apps\Wmc Builder\8.1 Features"Echo "Extracting Windows Iso & Moving Files""I:\Apps\GetWaikTools\x64\7z" x -y -oD:\Win81\Iso "I:\ISOs\Os\Windows_8.1_EN-US_x64.iso">"I:\Apps\Wmc Builder\Logs\8.1Extract.txt"Move "D:\Win81\Iso\sources\install.wim" "D:\Win81\Wim\":: Move "D:\Win81\Iso\sources\boot.wim" "D:\Win81\BootWim\"Echo "Mounting Image""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /mount-wim /wimfile:D:\Win81\wim\install.wim /index:1 /mountdir:D:\Win81\mountEcho "Setting Up Windows":: XKY4K-2NRWR-8F6P2-448RF-CRYQH (Windows 8 Professional):: RR3BN-3YY9P-9D7FC-7J4YF-QGJXW (Windows 8 Professional with Media Center):: FB4WR-32NVD-4RW79-XQFWH-CYQG3 (Windows 8 [Home]):: XHQ8N-C3MCJ-RQXB6-WCHYG-C9WKB (Windows 8.1 Professional):: GBFNG-2X3TC-8R27F-RMKYB-JK7QT (Windows 8.1 Professional with Media Center):: 334NH-RXG76-64THK-C7CKG-D3VPT (Windows 8.1 [Home])"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Get-TargetEditions"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Set-Edition:ProfessionalWMC"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Commit-Image /mountdir:D:\Win81\mount"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Set-ProductKey:GBFNG-2X3TC-8R27F-RMKYB-JK7QT"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Set-UILang:en-NZ"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Set-UILangFallback:en-US"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Set-Syslocale:en-NZ"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Set-UserLocale:en-NZ"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Set-InputLocale:1409:00000409"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Set-TimeZone:"New Zealand Standard Time""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Get-IntlEcho "Injecting Wmc Tokens"xcopy /s /h /y /k /g /c "I:\Apps\Wmc Builder\Wmc 8.1 Patcher\Data\x64\data.dat" "D:\Win81\mount\Windows\System32\spp\store\2.0.\"xcopy /s /h /y /k /g /c "I:\Apps\Wmc Builder\Wmc 8.1 Patcher\Data\x64\tokens.dat" "D:\Win81\mount\Windows\System32\spp\store\2.0.\""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Commit-Image /mountdir:D:\Win81\mountEcho "Injecting other files"xcopy /s /h /y /k /g /c "I:\Apps\Wmc Builder\Files\Hosts\hosts" "D:\Win81\mount\Windows\System32\driver\etc\"Echo "Enabling .NET 3.5 (include .NET 2.0 and 3.0)""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /image:D:\Win81\mount /Enable-Feature /FeatureName:NetFx3 /All /Source:D:\Win81\Iso\sources\sxs /LimitAccess"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Commit-Image /mountdir:D:\Win81\mountEcho "Adding Updates""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /ScratchDir:D:\Win81\Scratch /Add-Package /PackagePath:"I:\Updates\KUC\8.1\Updates">"I:\Apps\Wmc Builder\Logs\Updates.txt""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Commit-Image /mountdir:D:\Win81\mount"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /ScratchDir:D:\Win81\Scratch /Add-Package /PackagePath:"I:\Updates\KUC\8.1\zLast">"I:\Apps\Wmc Builder\Logs\Last.txt""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Commit-Image /mountdir:D:\Win81\mountEcho "Listing Packages/Apps""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Get-Packages>"I:\Apps\Wmc Builder\8.1 Features\Packages.txt""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Get-Features>"I:\Apps\Wmc Builder\8.1 Features\Features.txt""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Get-ProvisionedAppxPackages>"I:\Apps\Wmc Builder\8.1 Features\ProvisionedAppx.txt""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Get-Drivers>"I:\Apps\Wmc Builder\8.1 Features\Drivers.txt"Echo "Removing Uneeded Packages/Apps""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:microsoft.windowscommunicationsapps_2013.822.1740.2836_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.BingFinance_2013.809.632.3676_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.BingFoodAndDrink_2013.820.258.2561_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.BingHealthAndFitness_2013.813.243.3760_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.BingMaps_2013.809.2206.5385_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.BingNews_2013.809.636.2800_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.BingSports_2013.809.637.2803_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.BingTravel_2013.809.639.25_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.BingWeather_2013.809.641.3233_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.Reader_2013.822.1823.785_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.XboxLIVEGames_2013.808.1749.4769_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.ZuneMusic_2013.809.1658.2765_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.ZuneVideo_2013.809.1659.3015_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.HelpAndTips_2013.822.1812.1279_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.SkypeApp_2013.805.1159.2246_neutral_~_kzf8qxf38zg5c"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.WindowsAlarms_2013.822.1841.1043_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.WindowsCalculator_2013.822.1828.2633_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.WindowsReadingList_2013.822.1837.5741_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.WindowsScan_2013.822.1832.4879_neutral_~_8wekyb3d8bbwe"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Remove-ProvisionedAppxPackage /PackageName:Microsoft.WindowsSoundRecorder_2013.822.1835.2133_neutral_~_8wekyb3d8bbweEcho "Excess Features Disabled""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Disable-Feature /FeatureName:Microsoft-Hyper-V-All /FeatureName:Microsoft-Hyper-V-Tools-All /FeatureName:Microsoft-Hyper-V /FeatureName:Microsoft-Hyper-V-Management-Clients /FeatureName:Microsoft-Hyper-V-Management-PowerShell /FeatureName:Printing-Foundation-LPRPortMonitor /FeatureName:Printing-Foundation-LPDPrintService /FeatureName:Printing-Foundation-InternetPrinting-Client /FeatureName:ScanManagementConsole /FeatureName:LegacyComponents /FeatureName:DirectPlay /FeatureName:SimpleTCP /FeatureName:SNMP /FeatureName:WMISnmpProvider /FeatureName:Windows-Defender-Default-Definitions /FeatureName:Windows-Identity-Foundation /FeatureName:MicrosoftWindowsPowerShellV2Root /FeatureName:MicrosoftWindowsPowerShellV2 /FeatureName:DirectoryServices-ADAM-Client /FeatureName:Internet-Explorer-Optional-amd64 /FeatureName:IIS-WebServerRole /FeatureName:IIS-WebServer /FeatureName:IIS-CommonHttpFeatures /FeatureName:IIS-HttpErrors /FeatureName:IIS-HttpRedirect /FeatureName:IIS-ApplicationDevelopment /FeatureName:IIS-NetFxExtensibility /FeatureName:IIS-NetFxExtensibility45 /FeatureName:IIS-HealthAndDiagnostics /FeatureName:IIS-HttpLogging /FeatureName:IIS-LoggingLibraries /FeatureName:IIS-RequestMonitor /FeatureName:IIS-HttpTracing /FeatureName:IIS-Security /FeatureName:IIS-URLAuthorization /FeatureName:IIS-RequestFiltering /FeatureName:IIS-IPSecurity /FeatureName:IIS-Performance /FeatureName:IIS-HttpCompressionDynamic /FeatureName:IIS-WebServerManagementTools /FeatureName:IIS-ManagementScriptingTools /FeatureName:IIS-IIS6ManagementCompatibility /FeatureName:IIS-Metabase /FeatureName:WAS-WindowsActivationService /FeatureName:WAS-ProcessModel /FeatureName:WAS-NetFxEnvironment /FeatureName:WAS-ConfigurationAPI /FeatureName:IIS-HostableWebCore /FeatureName:IIS-CertProvider /FeatureName:IIS-WindowsAuthentication /FeatureName:IIS-DigestAuthentication /FeatureName:IIS-ClientCertificateMappingAuthentication /FeatureName:IIS-IISCertificateMappingAuthentication /FeatureName:IIS-ODBCLogging /FeatureName:IIS-StaticContent /FeatureName:IIS-DefaultDocument /FeatureName:IIS-DirectoryBrowsing /FeatureName:IIS-WebDAV /FeatureName:IIS-WebSockets /FeatureName:IIS-ApplicationInit /FeatureName:IIS-ASPNET /FeatureName:IIS-ASPNET45 /FeatureName:IIS-ASP /FeatureName:IIS-CGI /FeatureName:IIS-ISAPIExtensions /FeatureName:IIS-ISAPIFilter /FeatureName:IIS-ServerSideIncludes /FeatureName:IIS-CustomLogging /FeatureName:IIS-BasicAuthentication /FeatureName:IIS-HttpCompressionStatic /FeatureName:IIS-ManagementConsole /FeatureName:IIS-ManagementService /FeatureName:IIS-WMICompatibility /FeatureName:IIS-LegacyScripts /FeatureName:IIS-LegacySnapIn /FeatureName:IIS-FTPServer /FeatureName:IIS-FTPSvc /FeatureName:IIS-FTPExtensibility /FeatureName:MSMQ-Container /FeatureName:MSMQ-Server /FeatureName:MSMQ-Triggers /FeatureName:MSMQ-ADIntegration /FeatureName:MSMQ-HTTP /FeatureName:MSMQ-Multicast /FeatureName:MSMQ-DCOMProxy /FeatureName:WCF-Services45 /FeatureName:WCF-HTTP-Activation45 /FeatureName:WCF-TCP-Activation45 /FeatureName:WCF-Pipe-Activation45 /FeatureName:WCF-MSMQ-Activation45 /FeatureName:WCF-TCP-PortSharing45 /FeatureName:WCF-HTTP-Activation /FeatureName:WCF-NonHTTP-Activation /FeatureName:NetFx4-AdvSrvs /FeatureName:NetFx4Extended-ASPNET45 /FeatureName:Microsoft-Windows-MobilePC-Client-Premium-Package-net /FeatureName:Microsoft-Windows-MobilePC-LocationProvider-INF /FeatureName:RasCMAK /FeatureName:RasRip /FeatureName:TelnetClient /FeatureName:TelnetServer /FeatureName:TFTP /FeatureName:TIFFIFilter /FeatureName:MSRDC-Infrastructure /FeatureName:Printing-XPSServices-Features /FeatureName:SMB1Protocol /FeatureName:WorkFolders-Client /Remove"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /unmount-wim /mountdir:D:\Win81\mount /commitEcho "Mounting Image""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /mount-wim /wimfile:D:\Win81\wim\install.wim /index:1 /mountdir:D:\Win81\mountEcho "Cleaning Up Image""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Cleanup-Image /AnalyzeComponentStore"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Commit-Image /mountdir:D:\Win81\mount"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Cleanup-Image /StartComponentCleanuprem "I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /unmount-wim /mountdir:D:\Win81\mount /commit"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Commit-Image /mountdir:D:\Win81\mountEcho "Mounting Image"rem "I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /mount-wim /wimfile:D:\Win81\wim\install.wim /index:1 /mountdir:D:\Win81\mount"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Image:D:\Win81\mount /Cleanup-Image /StartComponentCleanup /ResetBase"I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Commit-Image /mountdir:D:\Win81\mountEcho "Commiting, Saving And Unmounting Image""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /unmount-wim /mountdir:D:\Win81\mount /commit"I:\Apps\GetWaikTools\x64\imagex.exe" /flags "ProfessionalWMC" /info D:\Win81\wim\install.wim 1 "Windows 8.1 Pro with Media Center" "Windows 8.1 Pro with Media Center""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Export-Image /SourceImageFile:D:\Win81\wim\install.wim /SourceIndex:1 /DestinationImageFile:D:\Win81\iso\sources\install.wim /compress:maximumxcopy /s /h /y /k /g /c "I:\Apps\Wmc Builder\Files\Ei.cfg" "D:\Win81\Iso\sources\"Echo "Deleting Support folder"DEL /F /Q "D:\Win81\iso\Support\*.*"RD /S /Q "D:\Win81\iso\Support"Echo "Building Iso...""I:\Apps\GetWaikTools\x64\oscdimg.exe" -bD:\Win81\iso\boot\etfsboot.com -h -d -u2 -m -lWindows-8.1-Pro-Wmc D:\Win81\iso "D:\Windows 8.1 Pro Wmc v1.0.iso"Echo "Modification Complete"PauseEcho "Clearing Existing Directories""I:\Apps\GetWaikTools\x64\Dism\Dism.exe" /Cleanup-MountpointsDEL /F /Q "D:\Win81\*.*"RD /S /Q "D:\Win81"Pause Edited February 2, 2014 by spidernz Quote
