Hallo,
i dont know if its a bug or it should be so, but for myself its really annoying.
Problem:
when i use Wim Manager and select a boot.wim and FROM Wim manager i click on the icon to get to ISO Maker, the "rebuild" checkbox disapear and when i click start (the folder Path is "C:\W"
and when i click start it failes (sure because thats not the path where my extracted iso folder is)
WHEN i select the install.wim all is OK (also when i select boot.wim and change the path manually)
and when i start wintoolkit and go directly to ISO Maker is also fine
i hope you understand what i mean
So far,
KrX
what i mean is when i select boot.wim in the WimManager (and mount it, do my stuff and dismount it), the boot.wim is still selected. and when i click on "Make ISO" i get this "bug".
i know i could select the install.wim to avoid it but when i do like 20 times mounting / dismounting it annoys me to do that each time.
so if making an iso with selected boot.wim is "impossible" it is for me a bug and should be fixxed ;P
try running WimManager  (run this program as administrator) when you right click on the WimManager program
i still personally thin that DISM GUI 3.5 is better to mount and dismount install.wim and boot.wim
