Hi Legolash,
with V. 1.4.29 he do all Updates to Basic --> Updates + Languages. It's fine and works!
With V. 1.4.32.5 he do some Updates to Advenced -> Sillent Installs + SFX
(KB947821, KB2574819, KB2685811, KB2685813, KB2809215, KB2819745, KB2857650, KB2862330)
but the some Updates works with V.1.4.29!!!!
Why?? I dont't understand and I take nevereless V.1.4.29 becouse bothers me.
Can you help me? It is (please) a bug?
With V. 1.4.29 it works!?!
But I believe the option exists to tell it NOT to move those updates if you are absolutely sure that your install will work correctly without them being moved.  Correct?
Hi Legolash,
i found today a new Bug. This Bug is since 1.4.32 - 1.4.33.6.
So whhen I say "make 4 Images Seleeted" then at passage 1
for example "Windows Home" he integrated all Updates correctly.
At the next passage 2 for example "Windows Home Premium"
he make all Updates faulty.
The same when with Windows Professional, Windows Ultimate ...
When I make all Images individually, than it works!!!
Hi Legolash,
next Bug Report:
with 1.4.29 and 1.4.32.5 the silent Mode works
with Microsoft Visual C++ 2008 Service Pack 1 /q correctly.
But with 1.4.33.6 it works aigain, but Windows
Update find this as a Update. But by 1.4.29 and 1.4.32.5 nt!
And the % in the Installer is no longer there
@Cartman586, I believe that you have used the forum "Report" function to try to report Win Toolkit "bugs".  That is not what the "Report" function is for.  It is supposed to be used ONLY to report apparent board violations to the moderators.  All of your "Reports" have been cleared and will be ignored.
For any Win Toolkit "bug" that you want to report, first be sure that you have made a search of the forum to see if it has already been reported and perhaps solved.  If it has not, then Lego has requested that a new thread be made in the Win Toolkit Bugs subforum for EACH bug, to make it easier for him to keep track of them.  So if there are bugs that you have "reported" but have not made a new thread for, then please do so.  Thanks in advance for your cooperation.
  • 4 months later...
