Posted February 14, 201411 yr My Windows 8.1 installation does not show the silent installers (any), it install better all the silent installers that I've added but don't shows the WinToolkit silent installer window, so what happens if one of my silent installers throws an error? totally unable to see it.. it's a bad idea to make this thing invisible. I'm not sure that maybe I've touched a setting that hides the installers or is a bug? I'm using the last 1.4.33.7 release, in 1.4.33.6 version this does not happen Edited February 14, 201411 yr by pitoloko
February 14, 201411 yr NSIS is an installer for what ? I didn't saw this error from NSIS til now !!In my installer does show this error, but not saying from which install it is ! I am very disappointed about my work in vain from 4 days until now! Edited February 14, 201411 yr by KEiGHT
February 14, 201411 yr Author @KEiGHT My English is very poor but, I din't understood you at all but I think that you've mixed things, NSIS is an install-builder (a software to build Installer files, compiling them into an exe, for example 'WinAMP' installer was made with NSIS installbuilder) My problem is not about the (polemic) 'NSIS Error' of winToolkit, in the version 1.4.33.7 this error seems fixed, but now there is a new problem and it's that the WinToolkit silent installer launcher is invisible! then the silent installers are installed totally silentlly and invisiblly so an user can't know how much long the installation can take to finish 'cause there is any WinToolkit window to display the silent installers count... Edited February 14, 201411 yr by pitoloko
February 17, 201411 yr Author the author of the app could say something about this change please? Edited February 17, 201411 yr by pitoloko
February 17, 201411 yr The author of the app is probably busy with Real Life. You will have to wait. Please be patient and wait quietly. Use the previous version in the meantime if it works better for you. Cheers and Regards
February 17, 201411 yr Author Ok the really issue seems to be with the Windows 8 installation screens (Those "Hello", "we are updating things", "we are blah blah blah", etc... that changes the colorization all the time) that screen misteriouslly hides completelly the WinToolkit installer from start to end, I've made again my ISO all from zero with the same settings in WinToolkit and now worked ok, I can see the WinToolkit installer @Legolash2oMaybe could be a good idea to set the WinToolkit installer Form 'OnTop' (several times after some seconds of execution time) to avoid this strange hidding issue Thanks for your great job. Edited February 17, 201411 yr by pitoloko
