When i try to apply autounattended.xml with full method i get this error.
Title: Unable to mount: HKLM\WIM_Software
ErrType: Error
Description: Win Toolkit could not mount '\Windows\System32\Config\SOFTWARE'. This can be caused by an anti-virus so try temporarily disabling it and try again.
Exception:
Exception:
Microsoft Windows [versio 6.1.7601]
Copyright © 2009 Microsoft Corporation.
C:\win7_data>Set SEE_MASK_NOZONECHECKS=1
C:\win7_data>"C:\Windows\System32\reg.exe" load HKLM\WIM_Software "\Windows\System32\Config\SOFTWARE"
C:\win7_data>exit
I'm using WinToolkit in clear VM environment so i don't have any anti-virus or other security apps installed. Full method worked fine before with the same iso. I tried a new win7 iso which i download via WinToolkit but i got same error. Quick method works fine. I guess it's a bug because full method worked with previous WinToolkit versions.
