WarZ Posted February 21, 2014 Posted February 21, 2014 I'm running an i5 cpu. Since integrating updates and drivers takes a bit of time, I'm wondering if its a problem if I play a game during the integrations ? Does wintoolkit need full cpu usage ? Will errors occur if I occupy the cpu with other programs ? Also, is it recommended that I perform the integrations in steps ? Or is processing updates and drivers at the same time fine ? I've noted some users seem to prefer incremental integrations vs all at once. However I'm not sure if thats just by preference or more effective / less errors ? Thanks ! Quote
Legolash2o Posted February 21, 2014 Posted February 21, 2014 1. I can't imagine it being a problem to play a game at the same time, may make the game a bit laggy. You can go into Options and set Win Toolkit priority anyway.2. It doesn't use full usage even if I wanted it to.3. Nope, no problems should occur. 4. Yeah some users integrate updates, make a new iso and then any other modifications works from that updated iso. Much better than integrate updates every single time. Quote
WarZ Posted February 21, 2014 Author Posted February 21, 2014 TY for the input, and the program is excellent. Top marks ! Quote
