So whhen I say "make 4 Images Seleeted" then at passage 1
for example "Windows Home" he integrated all Updates correctly.
At the next passage 2 for example "Windows Home Premium"
he make all Updates faulty.
The same when with Windows Professional, Windows Ultimate ...
When I make all Images individually, than it works!!!
In my case I think it has to do with either the MS february updates or changes in the some of the latest versions of WTK, because MS updates for January worked just fine.
Posted (edited)
Is there anyone on this forum who has solved this problem? I would be very grateful for tips!
Windows 7 x64 SP1 + a lot of updates :D
Edited by sweden8
I dunno what thats for updates.
Maybe are not integratable stuff.
Maybe are updates for "prequisite"
Means, example u have to integrate RSAT first, THEN the updates. for RSAT.
Use latest WinToolKit with "retry integrate" option.
Greez
Thanx BrokenZer0 - worked alot better now. But still KB2835361 and KB2834140 keeps popping up on WU ( after a clean install) although they are integrated - any ideas?
Did you integrate them in Normal mode or LDR mode?
also, did you integrate them before or after Platform Update KB2670838?
because those two are bi-updates, applicable with or without KB2670838
meaning they contains component for normal system (without KB2670838), and component for KB2670838
Hi,
I got a little bit same problem as above..some updates he won't integrate and then you get an x before the update.
All the rest got a green V next of the update...but what I don't get, mine computer is 5Hours bussy with integration of updates from win7_SP1_x64 and when I install it on a VMWARE, I see the integrated updates aren't installed?
Version WinToolkit = V1.4.32.2
All the rest seems to work fine.
thanx.
