General:
1) Cosmetic: I noticed that wtk opens in the center of that screen all the time but Alphawaves always opens off centre
2) Cosmetic: If you are wanting to keep consistency then the "new" tab should have everything categorized like the downloads tab and WHD
3) Also the options at the bottom similar to WHD would be cool
Note: Different program, I'm not intending for the downloader to look the same as WHD
4) BUG: If WHD and WTK are using the same lists/codebase it logically make sense that you can use either to keep the folder up to date.
however  WHD Downloads -->check with WTK, WTK chucks them into old/superseded the other way round WTK Downloads -->check with WHD seems to accept it just fine.
http://drive.google.com/file/d/0B_QNEP8RAKhsOUoxZDhHMWpBRUE/edit?usp=sharing
Under old/superseded
1) The delete old should be named either "Delete" or "Delete Old/Superseded" just keeping it in logical sense.
2) The check/uncheck all doesn't work see:
http://drive.google.com/file/d/0B_QNEP8RAKhsRE5kN0M2QVJqeEE/edit?usp=sharing
3) The files/tab is persistent, it would be wise if it was cleared when nothing is displayed, and only listing the updates for which ever specified list we've selected rather than it being for all?
http://drive.google.com/file/d/0B_QNEP8RAKhsM3llYXY3TW5yZlU/edit?usp=sharing
Ps: let me know if you find the video format more helpful, I was just testing it for now :)
PPs: it's better to dl the vids and watch them thru player like mpc/vlc
Edited by Legolash2o
