RAM disk 20gb)) dont be surprised memory used. BUT
after proccessing 4 images memory consumption was very high and didn't back to initial values before WT was launched.
I think WT got memory leak bug
OS right after start
so 7+ gb used and had not been released
after quiting WT system free only 200 mbytes
After you close WinToolkit you said the memory didn't go back down. Can you tell me which process was using it all please?
no such a process in the task manager list. everything looks normal, except free memory
Everything seems OK for me as the memory usage goes back to normal. Unfortunately I have no control over memory allocation and it's all controlled and done by the OS.The OS allocations memory when the application is ran and then wipes everything which was allocated after closing.
It should go back down on its own once Windows garbage collector has kicked in.
