jogtx16v Posted March 3, 2014 Posted March 3, 2014 (edited) Hello ! Im new with the wintoolkit integrator and silent install. I made usb bootable with all windows 7 version, x86/x64, 2 language pack and all windows updates. After 25 hours to integrated all updates in x86 and approximately same time for all x64 windows version. I noticed 4 errors at the end of x86 and 4 others at the end of x64 integration . now the installation make an error at ¼ before the end of the installation. .txt file in attachement. thank you . This software rock !all update x64 +winrar +adobe.txterrorintegrationx64.txt Edited March 3, 2014 by jogtx16v Quote
Legolash2o Posted March 3, 2014 Posted March 3, 2014 Those updates arn't integratable so just ignore the error and pretend everything worked ok. Make the iso and install Windows Quote
jogtx16v Posted March 3, 2014 Author Posted March 3, 2014 thank for your reply ! I already tried to install windows via usb key. but got an error at near the end of windows installation and I cannot continue installing. ( I will tried to take screenshot ). sorry for my english Quote
jogtx16v Posted March 3, 2014 Author Posted March 3, 2014 (edited) This is what I get in picture link attachement ... do you think my adobe reader and winrar silent installer can be the problem ? Its the first time I try a silent install. not 100% sure about it. The software I have use to download all update are : windows hotfix downloader . I have over 500 updates for x64 with this software but when I look to windows updates downloader 2.50 only 188 updates appears. thank for tipsimage link to onedrive.txt Edited March 3, 2014 by jogtx16v Quote
Legolash2o Posted March 3, 2014 Posted March 3, 2014 Some extra info on the failed updates: WMF4.0 requires .NET Framework 4.5 http://www.microsoft.com/en-gb/download/details.aspx?id=40855 Quote
abbodi1406 Posted March 3, 2014 Posted March 3, 2014 Do not integrate these categories: Additional\Not IntegratableAdditional\SUR ToolAdditional\WinREAdditional\Without PlatformAdditional\WMF4.0Additional\WUClient EXEExtra\BrowserChoiceExtra\DCA2.0 UpdatesExtra\French.EnterpriseExtra\NT.Backup.UtilityExtra\pl-plExtra\VirtualPCExtra\VirtualPC UpdatesExtra\WMF3.0Extra\WMF3.0 Updates jogtx16v 1 Quote
