Posted March 6, 201411 yr 32-bit Source: 7z938.msi64-bit Source: 7z938-x64.msiReleased: January 3, 2015About: 7-Zip is a file archiver with a high compression ratio.Removed:Language filesFile name: 7z938-x86-x64.exeSize: 1,62MBSilent Install Command: /aiMD5: 0BDCF8B26E63CE82FD16FBA0F06B60ABDownload: http://www.datafilehost.com/d/af27e761 Edited January 4, 201510 yr by kanyos
March 6, 201411 yr Hey, welcome...Tip: if you want to rebuild MSI with InstEd: Go to Media table, right click on the CAB and choose Rebuild selected CABs, now go to Tables menu, Sumary Info... change Image type from Admin external long to Compressed long BTW I customize my personal 7zip MSI installer using this MST, it allows the installer to keep the language support but they only install on non English systems (it also adds a add/remove programs icon)
December 27, 201410 yr Changes in 7-Zip 9.36 Beta, 2014-12-26:* The BUG in command line version was fixed: 7-Zip created temporary archive in current folder during update archive operation, if -w{Path} switch was not specified. The fixed 7-Zip creates temporary archive in folder that contains updated archive.* The BUG in 9.33-9.35 was fixed: 7-Zip silently ignored file reading errors during 7z or gz archive creation, and the created archive contained only part of file that was read before error. The fixed 7-Zip stops archive creation and it reports about error.* Some bugs were fixed.Homepage – http://www.7-zip.org
January 4, 201510 yr Author HelloThe 9.35 beta has been released~ Changes in 7-Zip 9.36 Beta, 2014-12-26:* The BUG in command line version was fixed: 7-Zip created temporary archive in current folder during update archive operation, if -w{Path} switch was not specified. The fixed 7-Zip creates temporary archive in folder that contains updated archive.* The BUG in 9.33-9.35 was fixed: 7-Zip silently ignored file reading errors during 7z or gz archive creation, and the created archive contained only part of file that was read before error. The fixed 7-Zip stops archive creation and it reports about error.* Some bugs were fixed.Homepage – http://www.7-zip.org 9.38 beta :beerchug:
February 13, 201510 yr Awesome. I wonder, can you add this nice tool: 7-Zip Theme Manager (http://www.7ztm.de) Thanks!
January 4, 20169 yr Can anyone update this or tell me how to make an AIO installer for the latest 7-Zip v15.14 ?
