About:
HWiNFO is a professional hardware information and diagnostic tools supporting latest components, industry technologies and standards.
Homepage: HWiNFO
Repack Features:
- Edited HWiNFO32.INI & HWiNFO64.INI for disable AutoUpdate--> AutoUpdate=0
- included UninsDeleteKey for cleanup:
  HKEY_CURRENT_USER\Software\HWiNFO32
  HKEY_CURRENT_USER\Software\HWiNFO64
32-bit
File: hw32_538_setup.exe
MD5: E6884FB30442A0D7C867BFC11393286A
Download: http://www.mediafire.com/file/nlxrrnk392sj17g/hw32_538_setup.exe
64-bit
File: hw64_538_setup.exe
MD5: F67EFDC69ED853508BC7A079CCB7881C
Download: http://www.mediafire.com/file/wq3eh2eizkdc5sv/hw64_538_setup.exe
Edited by kanyos
Any chanche to make it silent?
Thanks, Thiersee
only if using cmd with command: hw3264_436.exe /VERYSILENT
otherwise, no :)
Can anybody provide a mirror? For some reason, my ISP is blocking that site. Thanks
why blocked?
i like that site because download speed is fast
Are you sure it is your ISP that is blocking it?  Could it possibly be either a setting in your Firewall or AV, your DNS, or even your HOSTS file?  All of those could block the site.
I just found the culprit to my problem...it's the host file!!! Thanks bphlpt
Your welcome. :)
For any future problems, it is also possible that a browser extension can be at fault.  Only way to know for sure is if you disable each extension one at a time until they are all disabled, and then try a different browser for good measure.  Problems like this can be a royal pain to troubleshoot, but is is very rarely the ISP.
  • 6 months later...
HWiNFO32 & HWiNFO64
Changes in HWiNFO32 & HWiNFO64 v4.48 - Released on: Nov-26-2014:
  • Improved sensor indexing. For some addons (i.e. HWiNFOMonitor, Rainmeter) it will be required to download latest versions and reconfigure existing settings.
Fixed changing of sensor items order via the layout tab.
Added reading of sensor values from Aquaero (preliminary).
Improved support of Skylake-E/EP/EX.
Added a workaround for some crashes caused by Intel RST enterprise drivers.
Added ability to toggle RTSS/OSD output via a user-defined hotkey.
Improved Intel ME information.
Enhanced information returned for ASPEED GPUs.
Enhanced Broadwell-E/EN/EP/EX support.
Added ability to show/hide all sensor entries of a given type (temperatures, fans, etc.)
Added support of Giantec Semi GT34TS04 TSOD.
  • 4 weeks later...
HWiNFO32 & HWiNFO64
  • Fixed changing of sensor items order via the layout tab.
  • Added reading of sensor values from Aquaero (preliminary).
  • Improved support of Skylake-E/EP/EX.
  • Added a workaround for some crashes caused by Intel RST enterprise drivers.
  • Added ability to toggle RTSS/OSD output via a user-defined hotkey.
  • Improved Intel ME information.
  • Enhanced information returned for ASPEED GPUs.
  • Enhanced Broadwell-E/EN/EP/EX support.
  • Added ability to show/hide all sensor entries of a given type (temperatures, fans, etc.)
  • Added support of Giantec Semi GT34TS04 TSOD.
v4.50 :beerchug:
  • 9 months later...
