Posted March 9, 201411 yr Hello, when I put x86 and x64 version of Vista SP2 together in one WIM and the run the installer it becomes extremely slow when comes to accept eula, define partitions or chose which edition I want to install.I came across that problem few years back when made such AIO using command prompts only for integration, recently I did the same using WIM manager from winToolkit.Does anybody recognizes any possible soltion or at least cause of this problem? It's quite common according to my knowledge
