Tuesday77 Posted March 10, 2014 Posted March 10, 2014 Hey, What happened there?I did not integrate some LPs or other. Exception-Text:Title: 2 error(s) have occurredErrType: ErrorDescription: Win Toolkit has recorded errors which occurred during integration and have been stored via '>> Details'.Exception:Exception:An error occurred whilst integrating an update!Exception:Microsoft Windows [Version 6.1.7601]Copyright (c) 2009 Microsoft Corporation. All rights reserved.C:\Program Files (x86)\WinToolkit>Set SEE_MASK_NOZONECHECKS=1C:\Program Files (x86)\WinToolkit>"C:\Users\Z3R07\Desktop\GetWaikTools\Waik_4_1\x86\Dism\dism.exe" /Image:"C:\Mount" /Add-Package /PackagePath:"C:\Users\Z3R07\Desktop\Updates\General\Windows8.1-KB2883200-x86.msu" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.16384Image Version: 6.3.9600.16384Processing 1 of 1 - Adding package C:\Users\Z3R07\Desktop\Updates\General\Windows8.1-KB2883200-x86.msuC:\Users\Z3R07\Desktop\Updates\General\Windows8.1-KB2883200-x86.msu: The specified image is no longer serviceable and may be corrupted.Discard the modified image and start again. Error: 0x80070005Error: 5The specified image is no longer serviceable and may be corrupted.Discard the modified image and start again.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logC:\Program Files (x86)\WinToolkit>exit----------------------------------Something bad has happened to your image and can no longer be worked on! There was no point in continuing.NOTE: This usually happens when you try and integrate a language pack of some sort without integrating the Windows language pack first.-For example, if you want to integrate a French language pack for Internet Explorer. Then you need to make sure to add the French Windows language pack first!Exception:Microsoft Windows [Version 6.1.7601]Copyright (c) 2009 Microsoft Corporation. All rights reserved.C:\Program Files (x86)\WinToolkit>Set SEE_MASK_NOZONECHECKS=1C:\Program Files (x86)\WinToolkit>"C:\Users\Z3R07\Desktop\GetWaikTools\Waik_4_1\x86\Dism\dism.exe" /Image:"C:\Mount" /Add-Package /PackagePath:"C:\Users\Z3R07\Desktop\Updates\General\Windows8.1-KB2884846-x86.msu" /ScratchDir:"C:\Windows\Temp\WinToolkit\ScratchDir" /EnglishDeployment Image Servicing and Management toolVersion: 6.3.9600.16384Image Version: 6.3.9600.16384Processing 1 of 1 - C:\Users\Z3R07\Desktop\Updates\General\Windows8.1-KB2884846-x86.msu: An error occurred applying the Unattend.xml file from the .msu package.For more information, review the log file. Error: 0x800f0830Error: 0x800f0830DISM failed. No operation was performed.For more information, review the log file.The DISM log file can be found at C:\Windows\Logs\DISM\dism.logC:\Program Files (x86)\WinToolkit>exit---------------------------------- Help? :/ Quote
Thiersee Posted March 14, 2014 Posted March 14, 2014 (edited) Same problem here, but not at the same point as for BrokenZer0. Here happens on integrating IE11-LP-german: it stays 10 min.! on that position and finally appears the error. I got this issue since patch day 11.03.14 with WTK test 3 and 4, it was working perfectly before. I'll try now: 1) Test 4 with the INI without the last patches2) Test 2 with the INI before and after last patches. Edit 2:Point 2): OK with both INIPoint 1): no issue more!Very very strange, the only difference to yesterday (1.4.34.3) and today in the morning (1.4.34.4):I changed now the DISM-EXE (from C:\Windows\System32, before from WAIK) and the priority under "Option" to "High". Really, I don't understand the different behavior Edited March 14, 2014 by Thiersee Quote
Tuesday77 Posted March 15, 2014 Author Posted March 15, 2014 (edited) Without KB2883200 and KB2884846 it works without problems at my, dunno whats going there.. lol. Edited March 15, 2014 by BrokenZer0 Quote
Legolash2o Posted March 15, 2014 Posted March 15, 2014 So I can add them to the silent installers list? Quote
Thiersee Posted March 15, 2014 Posted March 15, 2014 (edited) So I can add them to the silent installers list?Even if I don't use Win 8.1: prerequisites for both are a running windows and KB2894179 installed! Prerequisites To apply this update, you must be running Windows 8.1, Windows Server 2012 R2, or Windows RT 8.1.Update 2894179 is a prerequisite of update 2883200 and update 2894029 on Intel Bay trail-based computers. Therefore, install update 2894179 before you install update 2883200 and update 2894029. Sources:http://support.microsoft.com/kb/2883200/en-ushttp://support.microsoft.com/kb/2884846/en-us Thiersee Edited March 15, 2014 by Thiersee Quote
