Posted March 11, 201411 yr Now i want to share InnoExtractor repacked by me :thumbsup:Source: IE_Install.exeAbout: Unpacker for Inno Setup-based installers. Extract the internal files and script without to run the setup.Tools used:Inno Setup 5.5.5 for recompile and edit script Removed:ToolbarsLanguage files except EnglishScript shellexec/postinstall/uninstallrun to web linkreplaced 7z.dll v9.20 with 7z.dll v9.34a Added into script:[installDelete]Type: filesandordirs; Name: "{userappdata}\InnoExtractor"Type: filesandordirs; Name: "{userdocs}\InnoExtractor"Type: filesandordirs; Name: "{localappdata}\Temp\InnoExtractorCache"[uninstallDelete]Type: filesandordirs; Name: "{userappdata}\InnoExtractor"Type: filesandordirs; Name: "{userdocs}\InnoExtractor"Type: filesandordirs; Name: "{localappdata}\Temp\InnoExtractorCache"Type: filesandordirs; Name: "{app}" [Registry]Root: HKCU32; Subkey: "Software\Classes\exefile\shell\InnoExtractor"; Flags: uninsdeletekey dontcreatekeyRoot: HKLM; Subkey: "Software\InnoExtractor"; Flags: uninsdeletekey dontcreatekey File name: IE_Install_Repack.exeSize: 1,72MBMD5: 778C4ADE35CE7E1EE78ED3E4744FE3C0Download: http://www.datafilehost.com/d/51993959 Edited October 28, 201410 yr by kanyos
June 4, 201410 yr Versión 4.7.0.155 is out. There is no repack for latest version, kanyos???? Thanks in advance!!!!! Edited June 4, 201410 yr by kamikase
June 4, 201410 yr Author Versión 4.7.0.155 is out. There is no repack for latest version, kanyos???? Thanks in advance!!!!!oh ya, i just know from you, thanks for info updated btw :type:
July 9, 201410 yr Author Thanks! And for latest version 4.8.0.156????? New version 4.8.1.157...Regards... ;-) ah, there are password in latest inno extractor installer, both v4.80 and v4.81 locked with password so, ya i've stopped repaking this program Final build for me, for my computer is v4.70 :welcome:and i would like to thanks to Havysoft Alegria for great tool: Inno Extractor :beerchug:
July 10, 201410 yr Thanks! And for latest version 4.8.0.156????? New version 4.8.1.157... Regards... ;-) ah, there are password in latest inno extractor installer, both v4.80 and v4.81 locked with password so, ya i've stopped repaking this program Final build for me, for my computer is v4.70 :welcome: and i would like to thanks to Havysoft Alegria for great tool: Inno Extractor :beerchug:I install InnoExtractor and copy files from this installer in Program Files (x86), after I repack with last ISS... by if that help you... Regards... ;-) Edited July 10, 201410 yr by alfreire
July 10, 201410 yr Simple... Use old installer source and add the new files to it after you grab them from the install dir
July 10, 201410 yr Simple... Use old installer source and add the new files to it after you grab them from the install dirThat's what I meant... X-DRegards... ;-)
July 12, 201410 yr Author Simple... Use old installer source and add the new files to it after you grab them from the install diryes i can now,i was almost frustrated...now i have latest inno extractor because of you sir thanks mr ricktendo :thumbsup:
July 29, 201410 yr New version 4.8.1.158 is out!Regards and thanks in advance, kanyos, great repacks of this useful tool!!! Edited July 29, 201410 yr by kamikase
August 1, 201410 yr Author New version 4.8.1.158 is out!Regards and thanks in advance, kanyos, great repacks of this useful tool!!! welcome back kamikase, updated :beerchug:
October 28, 201410 yr Author InnoExtractor 5.0.1.162 is out!!!!! i'm still using v4.7.0 because no Plus feature :beerchug:
November 16, 201410 yr Sorry for spam but have you tried InnoEx? It is distributed as portable but not a big problem to convert it to normal setup.
March 19, 20159 yr @kanyos: Do you have the repack build for latest InnoExtractor 5.1.6.176? Thanks in advance!!!
March 20, 20159 yr Author @kanyos: Do you have the repack build for latest InnoExtractor 5.1.6.176? Thanks in advance!!! @kamikase: no, because i still use version 4.7.0 :type: Edited March 22, 20159 yr by kanyos Removed warez link.
