Legolash2o Posted March 22, 2014 Posted March 22, 2014 I've managed to hopefully fix all the RunOnce issues with the latest test build 1.4.37.2. You dont have to start the process all over again, you just have to mount the image > unmount + save and you will have the new RunOnce. The link to the latest build can be found in my signature. Other fixes include:*1.4.37.1^FIX: Fixed updates issue with RunOnce*1.4.37.2^FIX: Fixed adding IE and XP Mode to AIO Updates*1.4.37.2^FIX: Minor fix to Alpahwaves Downloader*1.4.37.2^FIX: Minor fix to Update Retriever Quote
Cartman586 Posted March 22, 2014 Posted March 22, 2014 Hi, sorry it dosn't work :-( with 1.4.37.1 and 1.4.37.2 :-( Quote
Legolash2o Posted March 22, 2014 Author Posted March 22, 2014 Seems to be working perfectly fine for me :/ Quote
Cartman586 Posted March 24, 2014 Posted March 24, 2014 with V1.4.37.6 it dosn't work again :-( /q /norestart dosn't go Quote
© KEiGHT Posted March 28, 2014 Posted March 28, 2014 Is there a .ini file to see what is gonna be installed with RunOnce? because I receive and I see double installment !? Quote
Snow Posted March 28, 2014 Posted March 28, 2014 @LiamSeems to be working perfectly fine for me, too. Just tested. Quote
© KEiGHT Posted April 2, 2014 Posted April 2, 2014 (edited) Why this keep showing version of Installer RunOnce 1.4.37.16 instead of 1.4.38.4 ? Edited April 2, 2014 by © KEiGHT Quote
Legolash2o Posted April 3, 2014 Author Posted April 3, 2014 It shows the last version the RunOnce got updated. Quote
