Hi ,
I want to know how to add to my Windows 7 x64 setup installation this reg settings and I don't really know what is the string for that !
HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\ interface-name
add set TcpWindowSize REG-DWORD entry.
how to write in reg file to find exactly my adapter name from windows installation to put that REG-DWORD entry ?
Thank you
Edited by KEiGHT
Well, you cant, but instead you could use pwoershell or VBS script to detect adapter and inject that reg key after that for corresponding adapter.
There are plenty examples in the internet, how to Detect Adapter and change different parameters on it...
Edited by Etz
