March 27, 201410 yr Wintoolkit checks the source windows was installed from not the c drive add the driver folder to the source adding it in oem makes it so it doesn't exist when the toolkit runs. Setupcomplete runs after the toolkit runonce
March 27, 201410 yr Hi Kel. I don't think so. setupcomplete starts immediately after creating user. and what i know WinToolkit checks this way: %ANY ROOT%\Drivers AND %ANY ROOT%\sources\Drivers.
March 27, 201410 yr @LiamYes, you did it. Test with latest build works !! You're the BEST !! http://www.pic-upload.de/view-22680859/Unbenannt.png.html Edited March 27, 201410 yr by Snow
March 27, 201410 yr The latest build uses RunOnceEx, not sure if that runs before or after setupcomplete.cmd. Do you know snow? Glad it's working now!
March 27, 201410 yr RunOnceEx runs after setupcomplete. setupcomplete runs immediately after you create a user during windows setup. RunOnceEx does his work after user logged in and before desktop loads
April 2, 201410 yr Hi Lego, Did you edit install.ini as default to look like this ? [Config]INSTALLDIR=%DVD%:\WinToolkit_AppsDRIVERDIR=%DVD%:\Sources is something wrong if it looks like this ?
