Cartman586 Posted March 23, 2014 Posted March 23, 2014 Hi, more error than 1.4.37.4!!! at 1.4.37.4 the KB2670838 error at 1.4.37.5 (KB2670838, KB2786081, KB2882822) ERROR The build to build worse;-) And with 1.4.37.5 Silent Installer / RunOnce dosn't work!
Snow Posted March 23, 2014 Posted March 23, 2014 hi. i think your order of updates you integrate is totally messed. all windows updates goes to Updates section. and all with IE11 in name you should place in POSTREQUISITE section.
Cartman586 Posted March 23, 2014 Author Posted March 23, 2014 (edited) I can not Integrator with 37.5.See screen I know, and i have a Order :-) Lego, can you see the Problem? with the three KB? Edited March 27, 2014 by bphlpt Merged posts
Legolash2o Posted March 24, 2014 Posted March 24, 2014 Did those errors only appear in the last build?
Cartman586 Posted March 24, 2014 Author Posted March 24, 2014 (edited) Hi Lego,the problem are in Build:- 1.4.37.1 (IE11.exe dosn't work) black X and "More Images selected dosn't work"- 1.4.37.2 (IE11 + 3KB works) and "More Images selected dosn't work"- 1.4.37.3 (KB2670838 don't work) black X and "More Imgages selected works"- 1.4.37.4 (KB2670838, KB2786081, KB2882822 don't work) black X "More Imgages selected works"- 1.4.37.5 (KB2670838, KB2786081, KB2882822 don't work) black X "More Imgages selected works"This 3kb are Parts for IE11. Important!Try it, you see . Edited March 24, 2014 by Cartman586
Legolash2o Posted March 24, 2014 Posted March 24, 2014 If you put your mouse other them a tooltip should be displayed, hopefully saying why they wasn't integrated.
Cartman586 Posted March 24, 2014 Author Posted March 24, 2014 (edited) The Error Code for the 3KB (it's the same):This update may be needed so that you can integrate Internet Explorer 11.This update has NOT been integrated!:-(All other Updates work!Try it Edited March 24, 2014 by Cartman586
Legolash2o Posted March 24, 2014 Posted March 24, 2014 I've just released testbuild 6. In the Options tab tick 'Debug Updates' and then attach the Update log is makes in your Win Toolkit directory please. EDIT: I have tried it, works fine for me.
Cartman586 Posted March 24, 2014 Author Posted March 24, 2014 (edited) OK.But it Works by 1.4.37.2 by meIt's a language Problem? I'm german!www.comic-site.de/silent2.rar check this please (My Update Package with the 3KB and more)So now with v. 1.4.37.6 the KB Nummber is wake see Screen: (First line!)www.comic-site.de/bug.jpgHERE THE LOG:www.comic-site.de/logs.rarHe say 2 errors instead of 3!!! I Hope You can fix The Bug today :-( Edited March 27, 2014 by bphlpt Merged posts
Legolash2o Posted March 24, 2014 Posted March 24, 2014 I'm at University at the minute so can't do any coding yet.
Cartman586 Posted March 24, 2014 Author Posted March 24, 2014 (edited) Ok Dosn't work with 1.4.37.7 :-( Edited March 27, 2014 by bphlpt Merged posts
Legolash2o Posted March 24, 2014 Posted March 24, 2014 Haven't changed anything in regard to that for test 7. I have received an error log for KB2670838 though which may have caused it. http://wincert.net/leli55PK/Logging/01.04.37.07/2x695B4B98903A80F15BBA5D6272638C65_Ex06000230_frmAllInOne_de-DE_428163.log http://wincert.net/leli55PK/Logging/01.04.37.06/2x695B4B98903A80F15BBA5D6272638C65_Ex06000230_frmAllInOne_de-DE_557455.log
Cartman586 Posted March 24, 2014 Author Posted March 24, 2014 (edited) I don't know but KB2670838, KB2786081, KB2882822 dosn't work :-( So now with V. 1.4.37.8 KB2786081 + KB2882822 works :-) but KB2670838 dosn't work! V 1.4.37.9:Dosn't work: KB2670838 the same as above :-/ Silent Installer / RuncOne dosn't work :-/ Bug:Error Integrating UpdateException:0: | 1: Hotfix | 2: ALL | 3: 11,29 MB | 4: x64 | 5: C:\X\Patch\01 - Windows6.1-KB2670838-x64.msu | 6: B8481B87445AFAE01AE3A1AEB116F05C | 7: http://support.micro....com/kb/2670838 | 8: C:\X\Patch\01 - Windows6.1-KB2670838-x64.msu | ----------------------------------Error Integrating UpdateException:0: | 1: Hotfix | 2: ALL | 3: 11,29 MB | 4: x64 | 5: C:\X\Patch\01 - Windows6.1-KB2670838-x64.msu | 6: B8481B87445AFAE01AE3A1AEB116F05C | 7: http://support.micro....com/kb/2670838 | 8: C:\X\Patch\01 - Windows6.1-KB2670838-x64.msu | ----------------------------------Error integrating silent installer:Exception:Illegales Zeichen im Pfad.---------------------------------- Edited March 27, 2014 by bphlpt Merged posts
