[Solved] 1.4.37.6 - Silent Installer / RuncOne dosn't work with /q /norestart :-(
I'm so sorry
I can not let it :-)
Is In Release 7 KB2670838, KB2786081, KB2882822 fixed?
OK, i have try V 1.4.37.7 now.
You have for this Version no changelog.
- KB2670838, KB2786081, KB2882822 Probleme are open Black X (no fixed) :-(
- Silent Install / RunOnce
I have try it with the same programms and with the command /q /norestart.
With 1.4.37.7 it works again :-) YES ;-) - it is fixed in this V.
Ahhhhhhh,
Hey Lego,
now i see the problem with the Silent Installer / RunOnce Installer!
When you take a Original Image (Windows 7 SP1)
it works with
- Only Edition :-)
- More Images Selected :-)
so, when you take a modified Image (modified with Wincert)
and you integrate as extra stepp the programms then:
the Silent Installer / RunOnce Installer dosn't work with:
- Only Edition :-(
- More Images Selected :-(
try it, you can see it ;-)
Now i work today 10h for your project ;-)
Dosn't work with 1.4.37.8 :-(
It dosn 't work with 1.4.37.10 :-(
Edited by bphlpt
Merged Posts
