[Solved] 1.4.37.x - KB976002 ERROR - EU KB it works with correctly settings but ...
Hi Lego,
when i whil integrate the KB976002 (with Standard Settings in Options > Updates)
then he make an Error - Not compatible with SP1 (7601)! (see Screen 1).
So, when i disable under Option -> Updates (Compatibily Check, Failed Updates to
Silent Installers and Move Know Problem Update to Silent Installers (see Screen 2).
then he integrate the KB976002 correctly (see Screen 3).
And when i install Windows he has integrate the Update correctly and it works (see Screen 4)
Can you fixed it?
Here is the KB:
www.comic-site.de/kb976002.rar in X86 + X64!
