Posted March 24, 201411 yr Hi Lego, the KB's: - KB2574819- KB2592687- KB2603229- KB2685811- KB2685813- KB2830477- KB2857650- KB2862330 are default install in Wincert under Advanced -> Silent Installs + SFX (see Screen 1). But when i disable under Options -> Updates (Compatibility Check, Failed Updates to Silent Installersand move know problem Updates to silent installers (see Screen 2) He integrate the KB correctly (see Screen 3). And when Windows is installed the KB's are integrated and Windows Update found not this Updates ;-) All Versions have this Problem :-( Dosn't work with 1.4.37.8 :-( It dosn 't work with 1.4.37.10 :-(
March 26, 201411 yr Some times the updates integrate correctly, but prevent installation and cause some kind of error/issue during installation.
March 26, 201411 yr Author Try my complete Update Pack, you (deactivate Compatibility Check, Failed Updates to silent installers, Move know problem updates ....) you see all Updates integrated correctly and when windows start he found no KB Please take WinToolkit 1.4.34.5 (the best build it work) ;-) www.comic-site.de/X.rar (active in 10 min) you must be integrate a developer and Bug Fix hunter chat ;-)
