bug implemented since v 1.4.35 or 1.4.36
versions 1.4.36.*-1.4.37.* freezing after adding drivers, while all prev versions had no problems at all.
That may be so, but IIRC, adminxp has successfully made builds using previous versions of Win Toolkit that literally integrated many 100's of drivers, maybe 1000's.  Not that I would suggest the average user do such a thing, I certainly wouldn't, but if it worked in the past, then I believe it should keep working that way, as long as it doesn't mess something more important up, but that's just my opinion.
It's freezing after adding the drivers as it's on the last one. If I could see a screenshot of the latest version, I would be able to find out where it is freezing properly.
it was caused not by any driver- checked by removing last shown driver.
bug not occur WinToolkit_1.4.37.9 and newer.
All drives used by WT are local.
So the problem still exists or not?  ie no matter how many or which drivers are involved it always freezes on the last one?
So the problem does not occur for Win Toolkit versions newer than v1.4.37.9? The newest test version is good?
I just want to make sure I understand.
