Finally it worked! :prop: :punk: :dancing:
Thank you very much for your patience :type:
But there is a small difference. The edges of windows is black in VM, but they are White in real machine. (This may not be a bug. The edges can be White than the real machine install)
In VM edges (black):
In real machine edges (white):
Edited by oguz
Can't tonight but I'm sure it's something I can reproduce over VM. Do you have a link to the theme please?
Theme (i want it make default): http://www.datafilehost.com/d/66601a27
and
Theme pack: http://www.datafilehost.com/d/9665b60f
Your links are no longer working. I've download the link from your first post but I can't find the .theme file :/
Also test 5 is available with changes to the patching.
When I tested with built 4 on VM and chose all other “Windows Line 8.1” themes manually, the edges were still black. There was no problem with the original themes of Windows.
I haven’t got a chance to test it on a real machine yet. I’ll try it today. So i am not sure whether having edges black on VM is a real problem. :g:
If it is, i think 50% of the problem should be because of virtual box...
Edited by oguz
It won't work. It doesn't copy the Windows 8 Lines theme folder to the mount path.
At university at the moment whilst my computer is resizing a partition so it should be done later on today :)
Can the problem emerge when unpacking and copying nsis theme package?
By the way i got the backup of my real computer. If you want, u can use teamviewer and fix the problem tonight.
Hi Liam
If I don't tick Allow 3rd Party Themes, why after installing fresh copy of windows 7 ultimate x64 still get CLASSIC theme like XP mode and not AERO !?
Besides i force it in tweaks still come basic theme without AERO ! Is there any trick to escape from this issue ?
Edited by © KEiGHT
*AIO|v1.4.42.1|Thursday 19 June 2014  18:33:56
#Addons
D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\add-on\WinAMP_Pro_(Full_Edition)_ENU_x64_NotActivated.WA
D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\add-on\Reapers.7.Zip.9.32.Windows7.or.8.AddOn.WA
#Components
Australia Local Pack
Canada Local Pack
DVD Maker
Great Britain Local Pack
Inbox Games
Internet Explorer
Internet Games
Media Features
New Zealand Local Pack
Premium Inbox Games
Remote Differential Compression
Windows Media Center
Windows Media Player
Windows Media Player DVD Registration
Windows Media Player Network Sharing Service
#Drivers
D:\SOFTWARE\DRIVERS\D-LINK\DGE_528T_drv_revB1_v7_10_all_en_20130131\DGE-528T(EU)-Drv_V7.10b3\Driver\WIN7\Win7x64\NETDLKRT.inf
D:\SOFTWARE\DRIVERS\REALTEK\LAN\Driver_Win7_7080_03212014\WIN7\64\rt64win7.inf
#Files
TCPOptimizer.exe: :D:\SOFTWARE\INTERNET\TCP\REG\TCPOptimizer.exe;%SystemDrive%\Program Files\TCP\TCPOptimizer.exe;True
#Services
Windows Update::Manual
#Silent Installs
Intel Chipset Drivers 9.4.0.1026::-s;YES;36,30 MB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\infinst_autol\Setup.exe;Always Installed
Microsoft DirectX 9.0c June 2010::/silent;YES;98,16 MB;D:\SOFTWARE\MICROSOFT\DIRECTX\directx_Jun2010_redist\DXSETUP.exe;Always Installed
Firefox 30 (x86)::/s;NO;28,45 MB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\Firefox_30.exe;Always Installed
Adobe Flash Player Plugin 14.0.0.125::-install;NO;18,28 MB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\Adobe_Flash_Player_Plugin_14.0.0.125.exe;Always Installed
Adobe Flash Player ActiveX 14.0.0.125::-install;NO;17,72 MB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\Adobe_Flash_Player_ActiveX_14.0.0.125.exe;Always Installed
Adobe Reader 11.0.7.79::/sAll /RS;YES;125,94 MB;D:\SOFTWARE\PHOTO_TOOLS\AdbeRdr11007_en_US\setup.exe;Always Installed
Java Runtime Environment 8.0.50.13 (x86)::/s;NO;29,67 MB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\Java_Runtime_Environment_8.0.50.13_x86.exe;Always Installed
Java Runtime Environment 8.0.50.13 (x64)::/s;NO;32,55 MB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\Java_Runtime_Environment_8.0.50.13_x64.exe;Always Installed
WinRAR 5.10 (x64)::/s;YES;1,66 MB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\WINRAR\WinRAR_5.10.exe;Always Installed
Notepad++ 6::/S;NO;7,32 MB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\npp.6.6.6.exe;Always Installed
Setting Network Connections::/s;NO;193,58 KB;D:\SOFTWARE\WIN7SETUP\WIND\WININST\progs\Setting_Network_Connections_x64\NET.exe;Always Installed
#Tweaks
Add 'Services' to Desktop context-menu
Show 'Computer' on Desktop
Small Taskbar Icons
Always Show Menu Bars
Change Default Background: :D:\SOFTWARE\WIN7SETUP\WIND\WININST\walls\nvidia.jpg
Control Panel View::Large Icons
Disable 8.3 Name Creation
Disable Search Online on Unknown File Extensions
Disable Smart Window Arrangement
Increase Icon Cache
Remove Shortcut Suffix
Show Drive Letters First
Show Explorer Statusbar
Speed-up Access to AVI Media Files
Change Setup Background: :D:\SOFTWARE\WIN7SETUP\WIND\WININST\walls\setup.bmp
Open NFO files with notepad
Show Notepad Statusbar
Word Wrap in Notepad
Highlight newly installed programs::Don't Highlight
Computer::Link
Connect To::Hide
Control Panel::Link
Default Programs::Hide
Devices and Printers::Hide
Documents::Link
Downloads::Link
Favorites::Hide
Games::Hide
Homegroup::Show
Music::Hide
Network::Show
Personal::Link
Pictures::Hide
Recent Docs::Hide
Recorded TV::Hide
Run::Show
Videos::Hide
Use small icons on Start Menu
Enable context menus and dragging and dropping::Enable
Change Logon Background: :D:\SOFTWARE\WIN7SETUP\WIND\WININST\walls\nvidia.jpg
Disable Startup sound
Always Unload DLLs
Block Negative DNS Entries
Disable Auto System Sounds Leveling::Do nothing
Disable Bandwidth Limit
Disable Hibernation
Disable Window 7 built-in CD/DVD Burning
Disable Windows Error Reporting
Don’t allow Windows to turn off devices
Increase File System Memory Cache Size
Large System Cache::Enable
#vLite
Speech and Natural Language
Ease of Access Themes
Extra Themes
#Updates
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB967351-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB976042-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB999994-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2465285-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2466493-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2472264-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2502789-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2516889-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2519735-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2529825-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2554231-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2561821-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2575866-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2591271-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2591857-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2600100-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2614892-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2615327-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2615701-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2616386-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2618301-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2618535-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2618640-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2619260-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2624868-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2636963-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2638018-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2641618-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2641634-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2642357-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2648039-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2649904-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2652029-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2653312-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2659158-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2660677-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2661796-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2662288-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2664203-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2668395-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2670838-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2680243-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2685889-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2685893-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2686369-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2690750-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2691156-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2693187-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2695321-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2697479-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2697738-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2698957-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2699780-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2701373-v4-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2704299-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2707135-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2707157-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2710594-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2710832-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2717045-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2718841-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2719248-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2719305-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2721259-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2724133-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2725604-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2727107-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2732072-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2733955-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2735209-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2736469-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2738898-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2740180-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2740232-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2741416-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2742185-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2750692-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2752407-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2755105-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2755625-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2765067-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2765546-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2767671-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2768486-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2769121-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2780124-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2780410-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2784148-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2794422-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2796313-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2796725-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2796764-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2797749-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2799464-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2801423-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2809097-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2810177-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2812463-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2826164-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2829262-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2829537-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2831206-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2832829-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2833997-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2834911-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2835595-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2843376-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2846340-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2847295-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2847625-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2848224-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2851323-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2858684-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2860842-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2862067-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2866086-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2866772-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2870437-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2870467-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2872543-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2878035-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2880024-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2884172-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2884284-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2884927-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2885210-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2886366-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2892678-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2896146-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2896256-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2900635-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2905216-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2905407-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2906850-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2907020-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2912883-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2913763-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2914748-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2916627-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2918550-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2918833-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2918893-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2920486-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2921916-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2922059-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2923388-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2923766-v5-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2923884-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2924171-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2925489-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2926993-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2927111-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2927767-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2932119-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2932722-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2936341-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2936943-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2937668-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2939652-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2950358-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Hotfix\Windows6.1-KB2952507-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2570947-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2619339-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2621440-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2631813-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2643719-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2654428-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2690533-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2705219-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2727528-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2729452-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2736422-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2742599-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2756921-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2770660-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2803821-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2807986-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2835361-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2840631-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2844286-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2847311-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2847927-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2861191-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2861698-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2861855-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2862330-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2862335-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2863240-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2864202-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2868038-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2876331-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2884256-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2887069-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2892074-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2893294-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2894844-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2898851-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2900986-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2911501-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2916036-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2926765-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2929961-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2930275-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2931356-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2957189-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2957503-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\Security\Windows6.1-KB2965788-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB982018-v3-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2719857-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2732500-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2773072-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2779272-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2791765-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2799926-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2808679-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2818604-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2834140-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2852386-v2-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2856676-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2868116-x64.msu
D:\TEMP\Updatesx64\Updates\Windows7-x64\General\Windows6.1-KB2905454-x64.msu
#Options
Compatibility Check
Create Backups
Enable CMD
Integrate 'HDC' Drivers (boot.wim)
Integrate 'SCSIADAPTER' Drivers (boot.wim)
Integrate 'SYSTEM' Drivers (boot.wim)
Prepare Drivers
Prompt Addons
Prompt Drivers
Prompt Gadgets
Prompt Silent
Prompt Themes
Prompt Updates
Prompt Wallpapers
Rebuild Image
Remove Invalid Drivers
Retry Updates
Show Duplicates
Step-by-Step Integration
* As a side note, I've discovered something strange; If my system was patched for third party themes, automatic the windows release entered in wintoolkit it's altered (patched) and I don't know why this affects my build since I don't select allow 3rd party themes ?!
If my system hasn't patched already , the build works fine , (aero theme is set and work) ! very strange !
I think this is helpful !
Edited by © KEiGHT
Ease of Access Themes was to blame ! I've erased them but it's not indicated ! lol
Simple fact is my 3rd party theme just don't want to be applied !
Edited by © KEiGHT
Yes, I've checked, and wasn't any patch applied ! like I said up-there, some files needed (basic.theme and clasic.theme)!
Thanks for your reply ! :)
Edited by © KEiGHT
