ianymaty Posted March 27, 2014 Posted March 27, 2014 Since the other topic was marked as solved I opened another one. 1. Check All / Uncheck All don't work as it should. You need to Select with Shift or Ctrl than Check All tick only those selected. That's not how it should be. Crtl+A don't work either.Note: Fixed in v1.4.38.1 2. When open Downloader it opens on New tab and the bottom message is "Please select a category..." switch to Old/Superseded tab the message is there too. Switch back to New tab the message is "No new updates". Switch again to Old/Superseded the "No new updates." message is there too.When you switch between Downloaded tab and Old.Superseded. The message is "You haven't downloaded any updates." Basically switching back and forth through the tabs the bottom message from the last tab remains on the Old/Superseded tab too. After selecting a category and after the scan it ends on Downloaded tab the message is "No new updates..." Notice the trailing dots (...). After clicking on Check for Old Updates no more messages are displayed on any tab even if select another category. Hope you understand this behaviour description. Quote
Legolash2o Posted March 27, 2014 Posted March 27, 2014 I've managed to replicate some of these (haven't tried them all). Will most likely fix in the morning and then release the build to the public. Thanks EDIT: Done. Quote
ianymaty Posted March 28, 2014 Author Posted March 28, 2014 Sorry, in v1.4.38.2 Check All still not function as it should. Also Ctrl+A selection don't work. Quote
Legolash2o Posted March 28, 2014 Posted March 28, 2014 It hasn't been programmed in so it's technically not a bug. Quote
ianymaty Posted March 28, 2014 Author Posted March 28, 2014 OK. No Ctrl+A function available but how is this Check All thing work? It does not check all unless I select all with Shift click and tick the selection box. If right click on an item and select Check All nothing happens. Quote
ianymaty Posted April 4, 2014 Author Posted April 4, 2014 I still have the Check All problem in the latest v1.4.38.5. Quote
