March 28, 201412 yr Hi Liam. Is there a possible way to make this window that shows all programs that will be installed during RunOnceEx invisible ? thought about just deleting this registry key which i copy & paste from registry log of WinToolkit : HKEY_LOCAL_MACHINE\WIM_Software\Microsoft\Windows\CurrentVersion\RunOnceEx\001 | =Win Toolkit RunOnce | String maybe it's possible to make it visible or invisible via checkbox in WinToolkit's settings ?
March 28, 201412 yr Author It' more about cosmetic. this window stays the whole time. your silent-installer opens, but the window still stays in background. would be nicer look if it doesn't stay after Silent-Installer had started.
March 28, 201412 yr Author if it's possible anyway to make it invisible, could be advantage to have the choice. visible for debugging or testing reasons. invisible for nicer look.
March 28, 201412 yr Hi Liam. Is there a possible way to make this window that shows all programs that will be installed during RunOnceEx invisible ?.....Or at least to minimize it.
March 28, 201412 yr Author @Thierseeyes i would be satisfied, if at least minimizing this thing is possible
April 4, 201412 yr Author Hi Liam. After some testings with Setupcomplete i found this out: First I prevent the regular start you implemented it with deleting this registry key: REG DELETE HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx /f ------- Then i add this registry key: REG ADD HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx\050 /VE /D "WinToolkit RunOnce" /fif exist %WINDIR%\System32\WinToolkitRunOnce.exe REG ADD HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx\050 /V 1 /D "%WINDIR%\System32\WinToolkitRunOnce.exe" /f It shows similar to your way. The window is shown. ------- In next test i added ONLY this reg key: if exist %WINDIR%\System32\WinToolkitRunOnce.exe REG ADD HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx\050 /V 1 /D "%WINDIR%\System32\WinToolkitRunOnce.exe" /f ... and what happens ?!? there is no window which is interfering the optical beauty
