How to add windows Updates(msu files) into running system using DISM
sir can you please tell me How to add windows Updates(msu files) into running system(windows8.1/windows7sp1) using DISM.
i am using this command, i have copied the update files into folder "updates" on drive C.
c:\>dism  /online  /add-package  /packagepath:c:\updates
when i press enter after typing this command then message comes:
an error occurred, error=0X80070032
error=50
request is not supported.
what is the exact command?
You need admin privileges on the command first.
DISM commands cannot be run in a standard command prompt.
A quick (And REALLY easy to do) google search answered this issue:
http://blogs.technet.com/b/askcore/archive/2011/02/15/how-to-use-dism-to-install-a-hotfix-from-within-windows.aspx
Basically you cannot use msu files this way you need to unpack them and get the cabs...
