rulman Posted April 5, 2014 Posted April 5, 2014 (edited) Language Pack is not integrate("tr-TR") WinToolkit_1.4.38.5 is not work WinToolkit_1.4.34.14 && WinToolkit_1.4.35.1 && WinToolkit_1.4.36.2 not added driver's not working up all version "load ini" WinToolkit_1.4.33.7 Good Work Driver Integrate && Load "Ini" Edited May 18, 2014 by rulman Quote
© KEiGHT Posted April 6, 2014 Posted April 6, 2014 drivers are not showed there there is only to show integrated windows updates ONLY !to see where is drivers list , please mount and search in folder of C:\WinToolkit_Mount\Windows\WinToolkit\Drivers.txt Quote
rulman Posted April 7, 2014 Author Posted April 7, 2014 (edited) ***OPTIONS***fDrivers=C:\DriverfUpdates=E:\SystemMod\WIN8.1\Win8.1UpdatePack\x64sAICommands=TruesAVScan=TruesAIOSave=TruesUpdFilter=TruesPreventSleep=TruesCheckForUpdates=TruesDLogging=TruesFreeRAM=TruesLastDir=E:\SystemMod\WIN8.1\Win8.1UpdatePack\x64sLastWIM=E:\SystemMod\WIN8.1\sources\install.wimsPLastWIM=E:\SystemMod\WIN8.1\sources\install.wim|N/A|N/A|N/A|N/AsmCheck=FalsesAIOPM=TruesMountTemp=C:\WinToolkit_MountsQuickMerge=TruesFormSize=|frmWIMManager:1123*350smVerify=FalsesSolDownload=C:\Users\SAFS\Desktop\WinToolkit_1.4.38.5\Updates\sTransparency=100sTransparencyAll=FalsesWinToolkitDISM=NormalsWinToolkitExt=NormalsWinToolkitPRI=NormalsUploadLogs=TruesMountLog=TruesShowWelcome=FalsesRegistryLog=False ***STACK***get_GetStackTracePrepareLogSaveUploadPatchFilesIntegrateTweaksBWRun_DoWorkWorkerThreadStart_PrivateProcessMessageAsyncProcessMessageThreadPoolCallBackrunTryCodeExecuteCodeWithGuaranteedCleanupRunPerformWaitCallbackInternalPerformWaitCallback ***RAW_STACK*** konum: System.Diagnostics.FileVersionInfo.GetVersionInfo(String fileName) konum: WinToolkit.cThemes.GetVersion(String FilePath) konum: WinToolkit.cThemes.PatchUXInit(String sysFol, Boolean x64Mode) konum: WinToolkit.cThemes.PatchFiles(String WimPath) ***RAW_EXCEPTION***System.IO.FileNotFoundException: C:\WinToolkit_Mount\\Windows\System32\ konum: System.Diagnostics.FileVersionInfo.GetVersionInfo(String fileName) konum: WinToolkit.cThemes.GetVersion(String FilePath) konum: WinToolkit.cThemes.PatchUXInit(String sysFol, Boolean x64Mode) konum: WinToolkit.cThemes.PatchFiles(String WimPath) ***OPTIONS***fDrivers=C:\DriverfUpdates=E:\SystemMod\WIN8.1\Win8.1UpdatePack\x64sAICommands=TruesAVScan=TruesAIOSave=TruesUpdFilter=TruesPreventSleep=TruesCheckForUpdates=TruesDLogging=TruesFreeRAM=TruesLastDir=E:\SystemMod\WIN8.1\Win8.1UpdatePack\x64sLastWIM=E:\SystemMod\WIN8.1\sources\install.wimsPLastWIM=E:\SystemMod\WIN8.1\sources\install.wim|N/A|N/A|N/A|N/AsmCheck=FalsesAIOPM=TruesMountTemp=C:\WinToolkit_MountsQuickMerge=TruesFormSize=|frmWIMManager:1123*350smVerify=FalsesSolDownload=C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6\Updates\sTransparency=100sTransparencyAll=FalsesWinToolkitDISM=NormalsWinToolkitExt=NormalsWinToolkitPRI=NormalsUploadLogs=TruesMountLog=TruesShowWelcome=FalsesRegistryLog=False***STACK***get_GetStackTracePrepareLogSaveUploadPatchFilesIntegrateTweaksBWRun_DoWorkWorkerThreadStart_PrivateProcessMessageAsyncProcessMessageThreadPoolCallBackRunPerformWaitCallbackInternalPerformWaitCallback***RAW_STACK*** konum: System.Diagnostics.FileVersionInfo.GetVersionInfo(String fileName) konum: WinToolkit.cThemes.GetVersion(String FilePath) konum: WinToolkit.cThemes.PatchUXInit(String sysFol, Boolean x64Mode) konum: WinToolkit.cThemes.PatchFiles(String WimPath)***RAW_EXCEPTION***System.IO.FileNotFoundException: C:\WinToolkit_Mount\\Windows\System32\ konum: System.Diagnostics.FileVersionInfo.GetVersionInfo(String fileName) konum: WinToolkit.cThemes.GetVersion(String FilePath) konum: WinToolkit.cThemes.PatchUXInit(String sysFol, Boolean x64Mode) konum: WinToolkit.cThemes.PatchFiles(String WimPath) Edited April 11, 2014 by bphlpt added spoilers Quote
rulman Posted April 11, 2014 Author Posted April 11, 2014 (edited) drivers are not showed there there is only to show integrated windows updates ONLY ! to see where is drivers list , please mount and search in folder of C:\WinToolkit_Mount\Windows\WinToolkit\Drivers.txt Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win7\netathr.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win7\netathr.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win7\netathrx.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win7\netathrx.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win8\athw8.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win8\athw8.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win8\athw8x.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win8\athw8x.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win81Blue\athwb.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win81Blue\athwb.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win81Blue\athwbx.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win81Blue\athwbx.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN7\32\rt86win7.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN7\32\rt86win7.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN7\64\rt64win7.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN7\64\rt64win7.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN8\32\rt630x86.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN8\32\rt630x86.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN8\64\rt630x64.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN8\64\rt630x64.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\win32_153318\DisplayAudio\IntcDAud.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\win32_153318\DisplayAudio\IntcDAud.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\win32_153318\Graphics\igdlh.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\win32_153318\Graphics\igdlh.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\win64_153318\DisplayAudio\IntcDAud.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\win64_153318\DisplayAudio\IntcDAud.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Microsoft Windows [Version 6.3.9600] © 2013 Microsoft Corporation. T�m haklar� sakl�d�r. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>Set SEE_MASK_NOZONECHECKS=1 C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>"C:\Windows\System32\Dism.exe" /Image:"C:\WinToolkit_Mount" /Add-Driver /Driver:"C:\Driver\win64_153318\Graphics\igdlh64.inf" /English Deployment Image Servicing and Management tool Version: 6.3.9600.17031 Image Version: 6.3.9600.17031 Found 1 driver package(s) to install. Installing 1 of 1 - C:\Driver\win64_153318\Graphics\igdlh64.inf: The driver package was successfully installed. The operation completed successfully. C:\Users\SAFS\Desktop\WinToolkit_1.4.38.6>exit ###-----------------### Edited April 11, 2014 by bphlpt added spoiler Quote
rulman Posted May 18, 2014 Author Posted May 18, 2014 (edited) WinToolkit_1.4.38.7 && WinToolkit_1.4.38.7 Not Driver Integrate&& *AIO|v1.4.38.6|Sunday 13 April 2014 23:42:12#DriversC:\Driver\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Qualcomm Atheros AR9xxx 10.0.0.279 [ 08.01.2014 ]\Win7\netathrx.infC:\Driver\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\Realtek Ethernet Controller Driver 7.080 [ 18.2.2014 ]\WIN7\64\rt64win7.infC:\Driver\win32_153318\DisplayAudio\IntcDAud.infC:\Driver\win32_153318\Graphics\igdlh.infC:\Driver\win64_153318\DisplayAudio\IntcDAud.infC:\Driver\win64_153318\Graphics\igdlh64.inf#TweaksAdd 'Admin Tools' to Desktop context-menuAdd 'Manage' to Desktop context-menuAdd 'Open Elevated CMD here' to Folder context-menuAdd 'Services' to Desktop context-menuAdd 'Take Ownership' to context-menuAdd 'Register' and 'Unregister' to *.dll, *.ocx and *.ax Context MenuShow 'Computer' on DesktopShow 'Network' on DesktopShow User Folder on DesktopUnlock the taskbarAllow 3rd Party ThemesAlways Show Icons, Never ThumbnailsDisable Drive AutorunDisable Thumbnail CacheRemove Shortcut SuffixSpeed Up DesktopSpeed-up Access to AVI Media FilesChange CMD Text Color::Bright GreenWord Wrap in NotepadClear History on ExitDisable Default Browser CheckDisable First Run CustomizeDisable Password Caching in Internet ExplorerEnable Saving Encrypted Pages to DiskIE Homepage::www.google.comSet Google as Search ProviderTurn On Clear TypeUnlimited Simultaneous DownloadsHelp and Support::HideDisable User Account ControlDisable Admin SharesDisable Bandwidth Limit#OptionsCompatibility CheckCreate BackupsFailed Updates to Silent InstallersIntegrate 'HDC' Drivers (boot.wim)Integrate 'SCSIADAPTER' Drivers (boot.wim)Integrate 'SYSTEM' Drivers (boot.wim)Move Known Problem Updates to Silent InstallersPrepare DriversPrompt AddonsPrompt DriversPrompt GadgetsPrompt SilentPrompt ThemesPrompt UpdatesPrompt WallpapersRebuild ImageRemove Invalid DriversRetry Updates Error_1.4.38_1x8434A6EA12ADF25CAC036E2E38C35D62_Ex060039B2_frmAllInOne_tr-TR_647573.rar Edited May 18, 2014 by rulman Quote
